Offroad & 4x4
Air Down For Mud?
Old Jan 26, 2004 | 03:04 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Air Down For Mud?
I know, this sounds like a rookie question. For those of you that like to play in the mud, I was wondering if you air down your tires.
I've seen trucks running in tank traps that are obviously aired down but they also have to negotiate logs and stuff.
If you're just running in a bog, does dropping pressure help? I'd like to hear your experiences. Please include info on your rig like approx weight, and what tires you're running.
Old Jan 26, 2004 | 03:09 PM
Texan1983's Avatar
Texan1983
yea airing down helps. by puting down a wider foot print it will help with floatation and traction. i am no expert in the mud, but this is what i have heard and from some experiance have found out for myself. my rig weighs about 5100 lbs, and i am ashamed of my tires but they are 33x12.50
Old Jan 26, 2004 | 03:13 PM
proeliator's Avatar
proeliator
Yup, exactly what Tex said. Specs in sig.
Old Jan 26, 2004 | 06:57 PM
82f1504x4's Avatar
82f1504x4
yes airing down does help alot i have a 82 f150 with 33 12.50
they are remington mud brutes and they do very well
Old Jan 26, 2004 | 10:07 PM
cwb's Avatar
cwb
I go down to about 18 lbs
[IMG][/IMG]
Old Jan 27, 2004 | 02:09 AM
gilraine's Avatar
gilraine
I used to air down... I don't have bead locks and the first time I lost a bead in the middle of a bog was enough... never again.. took 3 trucks with winches 5 hours to get me out...
Old Jan 27, 2004 | 06:21 AM
tellico racing's Avatar
tellico racing
I run my rear 39.5" Boggers at 11psi. The front 40" gumbo's are set at 14.
Old Jan 27, 2004 | 02:44 PM
77'F-150Mudder
Thanks for the replies fellas. I haven't hit any mud nasty enough to need aired down yet I guess. The fact that my 9" broke the week before we started getting serious rain around here doesn't help.
CWB, that's some nice slop there. I wanna play sooooo bad!!
Old Jan 27, 2004 | 03:41 PM
proeliator's Avatar
proeliator
Telli, are you running 15" rims? Just curious. Sounds like Gil found out what happens when you air down 16.5s to much, bummer. With my weight and rims I only air down to 16 in the rear and 18 in the front...once taxes come back it will be beadlocks and 3psi though
Old Jan 27, 2004 | 03:47 PM
tellico racing
Yes they are 15's ..... I have yet to lose a bead......ohh I probably shouldn't have said that....knock on wood.
I got to those numbers by airing down while looking at the sidewall, and stopping just when they start to wrinkle.
I air down a little more at the dunes 9 rear 12 front.
Old Jan 28, 2004 | 01:29 AM
gilraine's Avatar
gilraine
I lost both tires on one side and I only had a rear limited slip...It is a real pain to reseat tires that are full of mud!@!!
Old Jan 28, 2004 | 04:22 AM
There Goes The Neighborhood's Avatar
Personally, I have found that airing down helps, but only in the rear. Before the swap to the 38's, the 35's on the rear were run at 4 psi, no beadlocks. We never blew a tire off the bead(could it be because we were running 14.5 inch wide tires on 8 inch wide rims), but constantly spun the rim inside the tire. So, it was run at 6 lbs with major tire spin, or run at 4 and tear up the tire. Or, as we did, option C, change to 38's. We run around 16 lbs on the rear, 21 lbs on the front, but we have to adjust for wheelspin, again. Keep the fronts higher, so the tread stays open and cleans out better. Usually 3 to 10 psi does it, but sometimes more.
Old Jan 28, 2004 | 11:02 AM
fishmanndotcom's Avatar
fishmanndotcom
sorry to bring this thread back but something just hit me....the more you air down the less clearance you have underneath. I would say if you are just playing without having to run through someone else's ruts, then air down. but i was keep as high as i could if you are going down the trail following someone's ruts! that extra inch or so could mean the difference b/t riding the rest of the day or spending several hours trying to get unstuck!
just my .02 worth
-jason-
Old Jan 28, 2004 | 12:44 PM
proeliator's Avatar
proeliator
Originally posted by fishmanndotcom
sorry to bring this thread back but something just hit me.... -jason-
Lemme guess, empty beer can crushed against your skull?
[Bthe more you air down the less clearance you have underneath. -jason- [/B]
Thats why God invented 44s...airing down costs you minimal clearance.
Old Jan 28, 2004 | 12:49 PM
85351ho's Avatar
85351ho
i think i saw a huge argument on pirate about airing down vs. clearance, and i think that airing down seemed to be your best bet
