only one flasher?
Old Jan 26, 2004 | 02:42 PM
ceprice's Avatar
ceprice
Question only one flasher?
I have a 1987 f150 4x4 351w today i had to jump start the truck (-44 last night didnt plug it in) now it is running fine but i have no signal or hazard lights. all other lights work including brake and there are no blown fuses.is there only one flasher for this or is it possible both are burnet out? thanks for any help you may have to offer
craig
Old Jan 26, 2004 | 03:30 PM
Franklin2's Avatar
Franklin2
Should be two flashers, one for the hazards, and one for the signals. I think one of them is mounted behind the fuse box.
Did they start working after the cab warmed up? And what's happening? Are you moving the lever, and the turn lights are coming on, but not blinking?
Old Jan 27, 2004 | 01:34 AM
ceprice's Avatar
ceprice
well it must have been froze. i let the truck run for 30 min it didnt work so i pulled the flasher out of the fuse panel to go buy another,they had none in stock,put it back in just to try and it worked, guess i know what to do tomorrow cause its going down to close to -50 tonight.thanks for the info on the other flasher dave i had no idea where to find it.
craig
