Oil Leak
Old Jan 25, 2004 | 09:38 PM
orlandoloop's Avatar
orlandoloop
Oil Leak
I have a 97 4.0 ltr. Ranger with an oil leak at the valve cover on the drivers side. I have the Haynes manual but cannot find detailed information to remove all of the "stuff" to get to the cover. Does any one have a set of directions or exploded view of the motor to help me figure just wath I have to do to get to the valve cover. While I am asking for the impossibe and ideas on an easy way to get to ALL the spark plug on both side to change them?
Thanks fo the help,
Michael
In Orlando, Florida
Old Jan 26, 2004 | 07:06 PM
Dealford's Avatar
Dealford
The upper intake manifold has to come off. The A/C compressor has to be unbolted And moved aside. Plug wires & a variety of vacuum hoses and the vacuum line to the P/B booster as well. There is also a mounting clip for the fuel line that has to be undone. If you have to disconnect the fuel lines, remember to relieve the line pressure first.
Old Jan 26, 2004 | 09:12 PM
hreed's Avatar
hreed
For the oil leak, try tightening the cover bolts. Most of the time they will loosen up with time, and a quarter turn will stop the leaks. Just be careful not to go too tight; the small bolts can snap off. 60-72 inch/pounds max.
jimmyb08SD
Florida Chapter
39
May 21, 2010 08:15 PM
BEAST428
Florida Chapter
15
May 4, 2010 06:20 PM
truckfreak69
Florida Chapter
Jun 9, 2009 08:35 PM
mercman86
2004 - 2008 F150
Dec 24, 2008 06:43 PM
jakegypsum
Feb 15, 2001 09:55 PM
