No reverse in a auto tranny
Old Jan 25, 2004 | 09:32 PM
Masterhawk's Avatar
Masterhawk
I have got a problem,
My 86 Ranger truck after it warms up, i loose reverse, is there a easy fix on that?????????
Old Jan 26, 2004 | 11:13 AM
hreed's Avatar
hreed
Probably no easy fix. Try flushing the fluid and change the oil and filter. I used "SeaFoam" to nurse a transmission through a winter but it was only a temporary fix. Does it work OK in the forward gears? Is the fluid level where it belongs and what does the fluid look like? Does it smell burned? Is the linkage adjusted properly? Check the vacuum lines. Make sure they are all connected. Just a few things to check. If all is well with these, you probably have internal mechanical problems meaning-out comes the transmission.
