460 operating temp
Old Jan 25, 2004 | 08:11 PM
Matute's Avatar
Matute
460 operating temp
Hi
I have swap a 1990 EFI 460 to in; I just wanted to know what would be the normal (and best) operating temp for this engine; without any big mods more than better exhaust and K&N admission.
regards
Matias
Old Jan 25, 2004 | 08:16 PM
i_alone's Avatar
i_alone
My 88 EFi 460 is running at about 195-200 degrees F , and more to around 190 here in the cold winter
Old Jan 25, 2004 | 11:45 PM
BLaCkSiLo's Avatar
BLaCkSiLo
my 84 carbed 460 runs at about 200-210 and never moves from that.. wont really be much of a help since its carbed, but o well
Old Jan 26, 2004 | 11:12 AM
scroob's Avatar
scroob
Since a 190 thermostat is stock, it should run at least that at all times.
190 is not "hot" and neither is 210. People who advise you to pull your thermostat or run a 160 because you are "overheating" your engine are misinformed, and are setting you up for problems later, like excessive cylinder wear and sludge buildup.
A properly pressurized cooling system with the correct mix of coolant does not boil until 230 or higher.
