What is the engine code letter in the VIN number that might tell you if the engine is original.400 engine code letter is an S and is the second digit in the VIN.
Vin #'s mean squat when determining the engine size on certain
engines like the 351M/400 or the 30/390.
You have to physically measure them.
The only way to verify what engine it is.... is to measure the stroke.
You do that by using a piece of dowel or rubber hose or something like that in thru the sparkplug hole.
You get the piston to BDC and make a mark at a point where you can get the second mark to it., Now bring the piston to TDC and make a mark.
If the distance is 4" the engine is a 400
If it is less than 4" te engine is a 351M.
