Power Windows
Old Jan 25, 2004 | 06:45 PM
grandin's Avatar
grandin
Question Power Windows
IT HAS SNOWED 5 INCHES IN 5 HOURS.... I WAS OUT IN MY 98 GATOR.... HAD TO PUT THE DRIVERS WINDOW DOWN... AND IT WILL NOT GO UP....... SO I TRIED ONE OF THE REAR WINDOWS AND IT WENT DOWN ABOUT AN INCH AND STOPPED..... NO OTHERS WORK...... THE POWER VENTS IN THE BACK WORK....
I NEED TO GO OUT TONIGHT....AND IT IS IN THE GARAGE.....STILL SNOWING AND BLOWING.....
I LOOK IN THE MANUAL TO SEE WHERE THE FUSE WAS LOCATED...BUT THE MANUAL DOES NOT IDENTIFY THE POWER WINDOW FUSE......
ANY THOUGHTS.......
98 GATOR
Old Jan 26, 2004 | 11:12 AM
the4by4freek's Avatar
the4by4freek
check your relays under your dash! I had the same problem with mine. I also had a problem with the radio, lighting,keyless entry, and so on and so forth. I found that if you wiggle the relays a bit in the fuse panel all will work again. I don't know whats up with it. I pulled all the relays and cleaned them and coated them with dielectric grease and replaced them. Haven't had any problems to date!
