1978 - 1996 Big Bronco
gas guage
Old Jan 25, 2004 | 04:46 PM
dyarumian's Avatar
dyarumian
gas guage
my gas guage hasnt worked sience i baught my bronco, it always reads empty no matter how much is in the tank. Is there any easy fix for this that you know of?
Old Jan 25, 2004 | 05:36 PM
BillyBob69's Avatar
BillyBob69
The easiest would be to check the panel fuses...but if all the other gauges work then forget that one. Otherwise, it could be the gauge itself, or the sending unit in the tank, or the float. Kinda depends on where you want to start.
Old Jan 25, 2004 | 06:55 PM
acerockola77's Avatar
acerockola77
Most of the times it ends up being the sending unit, just being corroded after years.
