2.8 vs. 2.9
Old Jan 25, 2004 | 12:53 PM
LxMan1's Avatar
LxMan1
Question 2.8 vs. 2.9
Hi everyone, I have a question.
Will the carb, intake etc. from an 84 2.8L bolt on to a 87 2.9L? I have a wrecked 87 Ranger with a EFI 2.9L in it and I was wanting to put the long block into a 84 Bronco II that has a grenaded 2.8L in it.
It looks to be the same design of engine (along with the 3.0 and 4.0) so I am thinking that the bellhousing, exhaust manifolds, intake manifols, and distributors will interchange.
Thanks,
Jimmy
Old Jan 27, 2004 | 06:16 PM
AlfredB1979's Avatar
AlfredB1979
Carb won't bolt on to a 2.9L
I have heard--not on my mind right now--about making an adapter for the 2.9L, but if you've got all the 2.9L gizmos, it would be easier to use all the and drop it into the 84.
A good bit of that stuff you mentioned *might* change over ,but with a good bit of work to them.....
Old Jan 27, 2004 | 07:15 PM
scroob's Avatar
scroob
I'm pretty sure that the intake won't work.
There is a lot more difference between a 2.8 and a 2.9 than meets the eye.
The timing gears in the 2.8 were replaced with a standard timing chain, which necessitated moving the cam upwards in the block. The block is taller.
Old Jan 27, 2004 | 10:21 PM
LxMan1's Avatar
LxMan1
Darn, OK thanks
shovelhead1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
51
Feb 21, 2014 10:28 AM
tom3tone
1983 - 2012 Ranger & B-Series
May 25, 2007 02:00 AM
87b2guy
Bronco II
Feb 21, 2005 12:59 AM
Boss_358
Dec 6, 2003 09:51 PM
jakask
Nov 29, 2003 11:03 PM
