Hot...Then Cool Temperature
Old Jan 24, 2004 | 09:35 PM
NewTruckGuy's Avatar
NewTruckGuy
Question Hot...Then Cool Temperature
The heater in my truck ('97 F150; 4.6L; 93K miles) will go from blowing hot air to cool air without touching the temperature ****.
If I turn the control **** to "OFF" for a minute or two and then back to "Panel/Floor"or "Floor" the temperature goes back to being hot again.
The needle is 1/4 inch above the bottom line of the temperature gauge and remains there no matter what temperature is coming from the vents.
Any thoughts on what may be causing this?
TIA...
Old Jan 25, 2004 | 02:23 PM
NewTruckGuy
I'm tired of freezing! I want Heat!
Old Jan 25, 2004 | 05:12 PM
Ultramagdan's Avatar
Ultramagdan
The system is topped off with coolant?
I found this bit of info posted by user vaders,
"The newer f150s don't have a valve in the heater hose to control the heat. Heat is controlled by an air damper in the heater box. The damper is controlled by a small servo motor unit on the bottom of the box and the position of the servo is controlled by the variable resistor connected to the temperature control **** on the dash. If you don't have heat, check the servo motor first. It's easy to get to and easy to replace."
This is a new one to me. Hopefully we'll get you fixed up.
Old Jan 25, 2004 | 06:37 PM
NewTruckGuy
Yes, the collant level is topped off and as soon as it stops snowing I will look for/check/replace the servo motor...
Thanks for the reply...
Old Feb 1, 2004 | 11:35 PM
bob arrington's Avatar
bob arrington
put a cold front on your truck, it could be something as simple as a piece of cardboard in front of the radiator and behind the grill ,bob
