Fried wire
Old Jan 24, 2004 | 08:24 PM
garybanjoman's Avatar
garybanjoman
Fried wire
I went to start this morning and noticed a burnt wire smell,went back later and no clicking when waiting on wait for start light to go off, any help? 1993 F-250 7.3 , only starts now after being hooked up to the hitching post.
Gary
Old Jan 25, 2004 | 09:36 AM
pnose's Avatar
pnose
Have a look at your ground wire from the gp relay to the valve cover or manifold,make suer it is clean and tight.
Old Jan 28, 2004 | 03:25 PM
garybanjoman
ground wire was in good shape, still will only start when warm or plugged up, does any one have any more suggestions
Gary
Old Jan 28, 2004 | 06:39 PM
ATC_250SX's Avatar
ATC_250SX
is the glow plug relay working properly?
Old Jan 28, 2004 | 07:01 PM
garybanjoman
i looked at what i think is the relay but didn't know really how to check relay, it was at the back of block behind the cdr valve, is this it? what procedure to do to see if it is working/
Gary
Old Jan 29, 2004 | 03:34 PM
bilder12's Avatar
bilder12
thats the one gary. you can check for 12 volts using a test lite. should show 12 on one of the bigger lugs and then on the other while cycling. (if it isnt broke) I dont know what the smell came from. Did it come from inside the cab or under the hood?
Old Jan 29, 2004 | 10:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Two big terminal bolts and two small terminal bolts on the top of the relay.
Big ones first,
Terminal 1, has a wire on it that should have battery voltage on it at all times.
Terminal 3, has a piece of flat metal that goes over to another terminal with wires on it. This is the glow plug wiring harness which should have battery voltage on it when the plugs are heating.
Small terminals,
Terminal 2, has two wires on it and it should have battery voltage on it when the key is in the run position.
Terminal 4, has a wire on it that goes down to the controller box under the relay.
The terminal numbers are not on the relay but I labeled them that way for future reference.
See with a test light if you have battery voltage on terminal 1 and if you have battery voltage on terminal 2 when the key is on. You can also check terminal 3 for battery voltage and then post the results back here, we will go from there next time.
Old Feb 1, 2004 | 05:23 PM
garybanjoman
Thanks Bilder and Dave, the relay was reading good on my
meter, but when i went to remove and clean connection's
the power supply post fell right off, got a new relay at Part's Plus
and every thing is back to normal.
Gary
