Sponsored by: Real Truck
4" Lift
Old Jun 12, 2002 | 02:53 PM
basstardo's Avatar
basstardo
4" Lift
Ok, so I'm gonna take the plunge and lift my truck up a bit. Never put a lift on a truck before, so this is new to me. I'm looking at a 4" Suspension lift, gonna run me around 1200 installed. The question I have is will I be able to fit 35's under the truck with that lift, and who would make 35's that will fit on the stock Ford Lariat rims? I'd like to get BF Goodrich or a comparable tire, but I don't want straight out mud tires. Also, can anyone recommend a good place to find aftermarket grills to replace the stock grill?
Thanks in advance!
basstardo
Old Jun 12, 2002 | 03:10 PM
Yeti's Avatar
Yeti
4" Lift
[updated:LAST EDITED ON 12-Jun-02 AT 04:11 PM (EST)]35"s will fit with a 4" lift although a 6" lift is recomended for proper suspension travel.
I will tell you that most people who go with a 4" wish they would of went with a 6" in the first place.
As far as tires on stock rims, I beleive at least a 8.25 wide rim is recomended for a 35"x12.50 tire , I am not sure how wide your stockers are.
As far as the grill, try E-bay.
Old Jun 12, 2002 | 03:14 PM
NoMo's Avatar
NoMo
4" Lift
The lift experts will be along shortly to give you better answers, but I'm sure that there are no 35" tires made to fit the OEM 16x7 rims. You'll probably want to go with a 16.5x9.75 rim to get more tire choices.
Old Jun 12, 2002 | 03:15 PM
NoMo's Avatar
NoMo
4" Lift
OK- so I type slow. :P
Old Jun 12, 2002 | 03:28 PM
buffy's Avatar
buffy
4" Lift
[link:www.eurekaboy.com/lifted.htm|Lifted Pictures]
I put 315/75R16's on the stock rims, and so far I've had no problems. They don't rub at all. My lift is 5.5".
Old Jun 12, 2002 | 03:29 PM
Yeti's Avatar
Yeti
4" Lift
[updated:LAST EDITED ON 12-Jun-02 AT 05:11 PM (EST)]Jeez Nomo, I almost thought you were trashing me until I saw your second post:-staun
I'm no expert ,but I do all my own lift and fab work at any point:P
Old Jun 12, 2002 | 03:36 PM
NoMo's Avatar
NoMo
4" Lift
Nope- you are one of the experts I was thinking about. I ventured off to some of the tire places to see what rim size they recommend for 35s.
Old Jun 13, 2002 | 03:11 PM
HIROLLN's Avatar
HIROLLN
4" Lift
Yea the 315/75's will fit they are the same size as a 35" tire ( just metric) they will clear just fine and yes they will fit on the stock rims! hope this helps! It is true about the 6" thing though! I wish I would have gone at least 8" now! :P :P :P :P
Old Jun 14, 2002 | 08:22 AM
RockyMountain250's Avatar
RockyMountain250
4" Lift
35's will fit on a 4" lift but they are not recommened for a rim any smaller than a 8.5 in and the stock one's are 7 in. A 10 in rim in my opinion looks the best but they will not fit on a 4 in lift they will hit the wheelwells. The 6 in lift is a better way to go as you will have room to grow. I was stuck between a 4 and 6 and am glad that I went with the 6 in Pro comp. Well happy hunting it is a tough decision but it is well worth it when you have the final product in the driveway.
Old Jun 14, 2002 | 09:35 AM
MrRottnDog's Avatar
MrRottnDog
4" Lift
>the driveway.
I agree! A 7" wheel is too narrow for the tire you want to use.
As stated an 8.5 would be fine... a 10 would be even better.
I ran 35/12.50/16's on 16x10 wheels with a 5 1/2" lift on my excursion with no problems. I beleive your truck sits about 2" taller than an excursion stock. It would seem that they should work.. I think there are a couple of guys with that combo here. Maybe they can comment?
I would go with the 6" over the 4". I wish I would have gotten the 8".
Old Jun 14, 2002 | 11:15 AM
NoMo's Avatar
NoMo
4" Lift
landcruzr
Nov 19, 2008 09:00 AM
basstardo
Jun 11, 2003 02:20 PM
basstardo
Jan 18, 2003 05:43 PM
basstardo
Jan 8, 2003 08:22 PM
