No backup lights: bulbs good/fuse good
1988 Ranger V6 Automatic
Neither backup lamp is working. Bulbs are good. Fuse is good.
Wiring diagram shows the "Neutral Safety Switch" inline but the truck starts ok in P and N. No start in anything else, so that would indicate the switch is functioning properly I'd think.
Any suggestions?
Any suggestions?
You being able to start with it in P or N shows that the switch is good I think.Do you have any problems shifting out of P with the truck running?If not,check the sensor on the side of the transmission.Your wiring diagram or a service manual should show you where it is.
Hope this helps.
Nightrain
Hope this helps.
Nightrain
The Neutral Switch can function and yet the other function may fail.
Hmmm...that may be it since everything else works.
Are the turn signals working? I think that the backup lights are part of that system also.
Yes, they're on the same circuit as the turn signals. Turn signals work fine.
Looks like I'll focus on the neutral start switch. My Haynes book shows two different types depending on the transmission.
Anybody know how I can tell whether I have a C5, C3 or A4LD transmission?
Thanks for the help.
Tony
Tony
I have the same model truck you do, except with a standard transmission, and the same problem. Apparently the person who owned it before me couldn't find what was wrong so he just installed a manual backup light. He took a wire from the positive post of the battery, pulled it through the wall between the engine compartment and driver's side compartment where some other wiring was already in place. He then drilled a hole in the instrument panel just above the fuse box and installed a manual switch. He then ran another wire underneath to the back of the truck where he attached the light to the bumper. (The body of the truck acts as the negative wire when the light is bolted down.)
However, if you go this route, be sure to install a fuse to the line coming from the battery and to wait until the very end to hook it up. The former owner forgot the fuse and when I was checking the wires near the fuse box looking for the source of another problem, I ended up with a small electrical fire. (Yow!)
Love and Light,
Charlotte
Love and Light,
Charlotte
