Sponsored by: Real Truck
how do i??
Old Jun 1, 2002 | 09:13 AM
Streetcruzer's Avatar
Streetcruzer
how do i??
Old Jun 13, 2002 | 07:15 PM
zoogme's Avatar
zoogme
how do i??
hello everyone,
how do i turn the buzzer off, when u have the key in?? it drives me crazy!!!
thanks,
carl
Old Jun 13, 2002 | 07:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
how do i??
Take the key out. :P
Hey, welcome to FTE! Do a search for buzzer. It's been discussed.
Old Jun 14, 2002 | 08:49 AM
stumpy2's Avatar
stumpy2
how do i??
Hey All! Its also in your owners manual, you just have to look a bit for it. Good luck!
2k1 F-250 SD EC SB 4x4 5.4 AT 3 1/2" Lift 285/75's True blue
Old Jun 14, 2002 | 09:51 AM
Monsta's Avatar
Monsta
Sit. Stay.
how do i??
Wait. Zoogme, you're talking about the buzzer or dinger that sounds when you have the key in the ignition and you open the driver side door, right?
Stumpy2, if there is a way IN THE MANUAL to defeat that feature, then do tell. But I think that you may be thinking about the "Belt-Minder" feature. That is in the manual.
Old Jun 14, 2002 | 09:51 PM
GORSTEP's Avatar
GORSTEP
how do i??
The switch is in the door latch. All you have to do is close the latch using a screw driver or the handle of a cresent wrench (better because you can see that the thing is latched and won't slam the door and wreck the latch). If the door thinks its closed then the dinger stops.
