Sponsored by: Kumho
brake question...
Old Jan 24, 2004 | 03:53 AM
Livsgrrl30's Avatar
Livsgrrl30
brake question...
Vehicle is a 97 ford explorer, Eddie bauer edition. I am unsure of the engine specifics... hopefully that wont matter... question is How is the brake caliper attached and held in place, along with the rotor... is it totally connected to the axle or is it removable?? Thanks in advance for your help! :-)
Old Jan 24, 2004 | 07:43 AM
lee's Avatar
lee
Hi,
While I am not familiar with your exact application, most calipers are held on with 2 long bolts that screw in from the back of the assembly. These may have a Hex, Torx, or Allen head.
As for the rotor, is your truck 2 or 4 wheel drive? If 2 wheel, then after you remove the caliper, remove the dust cover cap. It is located in the center of the rotor assembly. Under it you should find a cotter pin. Remove it and then you have access to the spindle nut. Remove it and then your rotor with bearings should pull off of the spindle.
Good luck
Old Jan 24, 2004 | 04:45 PM
Livsgrrl30's Avatar
Livsgrrl30
Originally posted by lee
Hi,
It is a 4 wheel drive.. sorry I should have said that earlier... Thanks
Old Jan 24, 2004 | 06:12 PM
lee's Avatar
lee
Oops,
Sorry I can't help you with the rotor question then as my ole 1970 has drums all the way around. Hopefully someone else will chime in.
Good luck,
