Sponsored by: Auxito
engine compatable?
Old Jan 23, 2004 | 07:44 PM
98 4.6 locked up's Avatar
98 4.6 locked up
engine compatable?
Thinking of putting a motor from a 98 Crown Victoria in my f-150 ext cab 4x4 with a 4.6. The crown Vic motor is also a 4.6. It came from a police car (interceptor). My motor is a romeo and from the info I got from the seller, so is the new motor. Will these match up? One potential problem is the new motor has COP's. Will I just be able to trash them and use my dual coil packs? Will the new motor have the mounting holes for the coil packs since they are both 4.6 romeo's of the same year.(by the way, the crown vic is a 98 also). I guess my question is are the blocks the same. It is the high performance engine and comes with a 130 amp alternator,etc. Any help would be appreciated. Thanks again.
Old Jan 23, 2004 | 08:13 PM
Racerguy's Avatar
Racerguy
As far as I know everything should bolt up.
A good autowrecker should be able to look in their interchange manual and tell you for sure though.
Old Jan 23, 2004 | 11:31 PM
98 4.6 locked up
Thanks racerguy, What are your thoughts on the COP's.
Old Jan 24, 2004 | 08:09 AM
Racerguy's Avatar
Racerguy
I believe that the plug wires and coils will all fit without any problems.
