Will this hurt my truck if I run with my hubs locked for a 250mile trip.
I am going on a trip tonight, leaving in a couple hours. It is 120 miles one way and the road conditions are questionable. I will most likely run in 2wd @ about 65MPH (pending road conditions), but am very likely to run into some bad conditions.
I'm no mechanic, but all I've ever been told is that it is better to leave your hubs locked in all the time than not, as it circulates oil and keeps things lubed up and ready to go for when you do decide to use it.
From what I've been told, the only drawback is fuel economy as your you are offering up a little more resistance to movement by having your front axles and gears turning all the time.
I personally notice very little loss in fuel economy in my pickup (95 Ford F-150, 5-sp, 300-6.) and I tend to keep my hubs turned in more often than not.
If someone out there has more knowledge on this subject than I, please feel free to chime in.
Swanny has it about right. You will obviosly have some additional wear of your front axle assemble, but we would be talking FAR more miles then you are talking about.
He is also right about engaging the front axle now and then. The moisture build up can cause some oxidation (rust) build up if it not brought up to temperature now and then also.
I saw one lock up in the summer one time, too. BAD NEWS. That however, was as isolated an incident as a rear end locking up. You will be fine, and it never hurts to keep the oil flowing once and a while.
The manual actually recommends doing this periodically to keep things lubed. I think they recommend 10-20 miles as enough to juice things up.
As far as 250 miles, you are looking at wear and lower mileage and some road rumble. I would think ahead and unlock them as much as road conditions would allow. For example if you think 100 straight miles of the 250 will be clear I would unlock them for that mileage.
Part time 4WD is not meant to be used all the time so I like to save my wear and tear when I can. But I have never heard of wearing one out.
I am no expert but I would say you are probably safe as long as you keep things reasonable. A little wear is a fair trade off for safety.
I run mine locked all the time in the winter. Or at least if the roads are bad or there is a threat of the roads becoming bad. Everyone is pretty much right. It keeps everything functioning. Like the saying goes, "If you don't use it, you lose it."
I have never had my hubs not lock when I selected the ESOF to 4x4...
If the ESOF does fail to lock the hubs (vacuum failure), you can then get out and lock them manually and keep any worries about the extended high speed trip with locked hubs to a minimum.
As a side note, a buddy of mine (Chevy of course) had his 4x4 system fail on him based on a solenoid malfunction. When he selected 4x4 with his manly, floor mounted "it will always work 'cause it's manual" shifter, the transfer case tried to shift over to 4x4 but the solenoid which locks his front hubs failed. This basically showed him his ESOF is operated by his floor shifter. Ford has taken care of us in this respect with the auto hubs you can manually lock.
The '92 does not have the vacuum system. The manual ones will not lock automatically. There is no problem running them locked for a few hundred miles. I do the same thing when snow may be encountered here on the mountain.
I've heard there are lots of problems with the auto/manual hubs. Where the auto lockers are failing.
I personally prefer manual. Cause you can dissengage the hubs manually and ensure that they are dissengaged. No fear of electronic failure, or malfunction.
