High Idle
Old Jan 23, 2004 | 10:23 AM
DonnyT's Avatar
DonnyT
High Idle
Hello
I have a 1988 F150 4x4, 5.0L. It is idling very high and will maintain 32MPH with foot off the accelerator. I cleaned the the throttle plates. I noticed (finally) that I had no Check engine light when starting the truck. I found that there was no bulb in the check eng lamp holder. I installed the bulb and I now get a flashing check engine light when accelerating. I wanted to read the codes myself usingf the check eng light. Where is the test connector and are there any other troubleshooting advice?
Old Jan 23, 2004 | 01:13 PM
beartracks's Avatar
beartracks
Don't know about the codes but I would suspect a vacuum leak or thottle position sensor to start. On many vehicles you can short two pins on the al/dl connector and get the light to flash the codes.
Old Jan 26, 2004 | 07:20 PM
DonnyT's Avatar
DonnyT
Problem Fixed! The upper intake manifold gasket was blown. Thanks for the input.
Old Jan 27, 2004 | 05:03 PM
99expxltgold's Avatar
99expxltgold
how did u find out the problem?
