Yes, but I've never seen high heat chrome paint...You do not need high heat paint for the block, but if memory serves the heat resistence of some of the speciality paints such as chrome have a much lower heat threshold than regular paint.
I've see pictures of someone on this forum who painted their Exhaust manifold a "chrome" color and it looked great! But I don't want to go through the trouble of painting it and have it burn off too quickley. Know what I mean.
The intake isn't gonna get that hot to burn off paint. BTW, what engine do you have? The only time I've seen paint burn off an intake is the old Y-block with its air-gap style intake and exhaust crossover in the center. The paint burns only about an inch above the crossover passage.
If it's cast-iron I'd say paint it. You should be able to get 500* paint, but do not bother with home improvement stores. A good body shop should help you out.
Do you want to brush it on? I've seen pics of brush paint engines, and they looked good to me. Cheaper too.
There are very few coatings that will hold up on exhaust manifolds. The exhaust manifold often will get over 500 deg in certain situations (lugging, or if your engine is a little out of tune).
The best paints are rated to 1500 degree, or of course, you can go with ceramic coatings. The 1500 deg paints are not really paints -- you spray them on, then BAKE the thing in an industrial oven at 500 degrees for an hour or so.
You can come close in your wife/girlfriend/mothers oven, but you might be single/alone/orphaned shortly thereafter.
I seriously doubt it is worth your trouble to try any of the current "chrome" paints. The high temp paint does come in a silver. I like black so its harder to see the areas where it has burned off!!
