not getting fuel to engine
Old Jan 22, 2004 | 11:08 PM
tattoofool's Avatar
tattoofool
I have recently purchased a 1971 longbed truck for three hundred dollars i can't get any fuel the engine which is a 302 any suggestions already checked fuel pump. I know it might be the fuel filters but is it possibly a problem with the fuel pickup.
Old Jan 22, 2004 | 11:42 PM
Superdave's Avatar
Superdave
tattoofool
Have you established that the mechanical fuel pump is working?
Like, you hooked it to an outside fuel source and it pumped fuel?
But yes, the other things you mention can be problems as well.
If the tank is original, the pickup could be plugged up with crud from the old tank.
Old Jan 23, 2004 | 12:03 AM
tattoofool's Avatar
tattoofool
Superdave what is the best way to get rid of the crud
Old Jan 23, 2004 | 12:12 AM
f100guy's Avatar
f100guy
replace the tank or get it reconditioneddddddddd
Old Jan 24, 2004 | 11:12 PM
Superdave's Avatar
Superdave
tattoofool
Yeah, It would be pretty much like f100guy says.
Its pretty time consuming trying to clean one out completely, the tank could be rusting from the inside.
You would just have to remove it and evaluate the situation when you can see inside the tank.
Old Jan 25, 2004 | 01:47 AM
LxMan1's Avatar
LxMan1
Stick a hose from the fuel pump into a gas can with gas in it and see if it will pump that up to the carb.
The hose from the tank to the frame could be dry rotted and allowing air to be sucked into the line instead of fuel.
Old Jan 26, 2004 | 07:13 PM
tye sheats's Avatar
tye sheats
make sure there are no kinks in the lines too!
marc21387
Jun 18, 2012 11:15 AM
Mr. Badger
Jan 12, 2011 06:44 PM
60RatRod
Oct 12, 2010 08:08 AM
rob71458
Aug 28, 2009 08:31 PM
jonvanzanten
Sep 1, 2007 10:18 PM
