Changing fluie
Old Jan 22, 2004 | 09:02 PM
plowboy2155's Avatar
plowboy2155
Changing fluie
I have a 1996 F-350 with a powerstroke diesel and an automatic transmission. There is a drain plug on the torque converter and I plan to drain it. I need to know how much fluid I need to buy to put back in it. Any input would be greatly appreciated. Thanks in advance.
Old Jan 23, 2004 | 09:45 AM
jim henderson's Avatar
jim henderson
For a full pan and Torque converter change you are going to need a lot of fluid. While you are at it drain the cooler too.
From what I recall, the E4OD, which is what I think you have takes something like 15 quarts of fluid. If you have a manual double check that. I assume the diesel and gas versions use the same amount of fluid, I don't know for sure.
In any case you will need a lot. Be sure to change the filter while you are in there.
Good Luck,
Jim Henderson
Old Jan 23, 2004 | 04:47 PM
Casey's Avatar
Casey
Here is some more information about changing ATF:
https://www.ford-trucks.com/articles...hangingatf.php
drpaul311
Oct 24, 2012 03:18 PM
littlegreenford
Modular V8 (4.6L, 5.4L)
Dec 14, 2008 11:29 AM
steuben
Nov 8, 2008 01:20 AM
afsigma21
Apr 9, 2008 11:33 AM
skl
6.4L Power Stroke Diesel
Nov 10, 2007 10:04 PM
