Bad catalytic converter?
Old Jan 22, 2004 | 02:59 PM
Jimmn's Avatar
Jimmn
I am still trying to get my '81 F-100,( with a 300/6 with 75K) engine to run better. Starts great, but after a few miles boggs down when I accelerate especially when shifting into higher gear and rpm's are low.
A few people have said it may be my catalytic converter. Is there a easy way to check this. Would banging on it loosen things up? Can I just take it out, or replace?
Also may be a carb problem, or ERG valve (if I even have one) Two mechanics have looked at it and said everything looked OK, seems to start and idle fine, but does not drive well when it is below zero.
Thanks Jim
Old Jan 22, 2004 | 04:20 PM
wildjon300ci's Avatar
wildjon300ci
Hmm..only does this when cold? If so, methinks you have a case of carb icing.
Old Jan 22, 2004 | 07:13 PM
plowpusher's Avatar
plowpusher
the way to check a converter is first with the truck running put your hand to the tailpipe you should feel the exhaust pulsating if the coverter goes bad it will feel like the output of a shop vac you can also check the exhaust pipe it will be really hot in front of the converter and much cooler behind the converter or you can take a 3/8 drill and put one hole into the pipe before and one hole after the converterfeel the differance in flow
Old Jan 22, 2004 | 11:49 PM
rainbowATF's Avatar
rainbowATF
I think I saw a procedure that uses just a vacuum guage and observation during starting or reving engine etc. Vacuum drops to 0 then recovers slowly. Don't remember what it is for sure.
Old Jan 23, 2004 | 01:52 AM
howler's Avatar
howler
if you bang on your converter, drop the exhaust pipe, otherwise you will fill the muffler when it crumbles....
ffdemoss
Oct 23, 2018 11:32 AM
loseboltssinkships
Jan 5, 2011 09:53 AM
cujo8
38
May 22, 2006 10:36 PM
scottddove
Mar 15, 2006 11:44 AM
BillNYS
25
Dec 20, 2004 06:30 PM
