Is it a C6 or a C4?
Old Jan 22, 2004 | 06:47 AM
joadmobile's Avatar
joadmobile
Is it a C6 or a C4?
Researching my earlier 4x4 auto compatibility post, I have come upon a big question. I can't tell if I have a C4 or a C6 auto transmission. The factory codes on the door plate say that I have a C6, and I know the original tranny is still in the truck. However, if you go by the diagram in the LMC catalog and look at the transmission pan, it is a C4 according to them (the pan is rectangular, it has 4 straight sides). Anyone know what gives? The truck is a 71 LWB 4x2 Sport Custom with stock 302, Ford 9 in rear.
Old Jan 22, 2004 | 08:42 AM
gtex's Avatar
gtex
Sounds like a C4, seeing as it's behind a 302.
Is the engine original as well. I'm not sure they ever put a c6 behind a 302 motor in any f Series. I'm sure I'll be corrected if mistaken.
Old Jan 22, 2004 | 09:10 AM
Ratsmoker's Avatar
Ratsmoker
Thye did put C6s behind some small blocks. Just look at the pan. If its square you have a C4. If its L shaped out have a C6.
Old Jan 22, 2004 | 09:17 AM
joadmobile's Avatar
joadmobile
That's what I figured - except why in the world would Ford's own data plate and shop manual say it is a C6? I know both previous owners and the tranny has never been changed out, only rebuilt once. I am going to measure it after work today - according to the tranny guide in the transmission forum a C4 is 17 or 18", a C6 is 20". It may be a C6 going by this from the transmission guide:
1966 - 75 have rectangular pan with 17 bolts & long measurement on front and rear edges. Shorter on sides
Guess I'll be counting the bolts as well.
Old Jan 22, 2004 | 09:52 AM
4WD67F250's Avatar
4WD67F250
dude...
is the torque converter cover part of the main case of the transmission?(ie: one piece from engine block to tailshaft housing) if it is its for sure a C6, if it has one that unbolts(like an old standard tranny) its either a C4 or a fordomatic.
I asumme the maincase is all aluminum?
if it is, its not a fordomatic/FMX.
Old Jan 22, 2004 | 10:01 AM
joadmobile's Avatar
joadmobile
If memory serves it is all one piece and aluminum, but I have found myself to be unreliable in the past.... I called my wife at home and she was reluctant to crawl up under the truck, so I guess I'll have to wait until tonight to check and see. I'll let you guys know - thanks for the help!
Any idea how I could adapt this C6 to a 4X4? Will just changing the tailhousing and output shaft (no small feat, I know) suffice?
Old Jan 22, 2004 | 10:12 AM
4WD67F250's Avatar
4WD67F250
yes, you will need the right shaft and adapter/tailhousing that goes with the T-case you plan to use.
Old Jan 22, 2004 | 04:18 PM
joadmobile's Avatar
joadmobile
Well, it turns out that it is a C-4. The bell housing is detachable and there are 11 bolts on the almost square transmission pan. That is so weird seeing as how the warranty plate says the transmission type is G, which decodes as C-6 for 1971. In fact, I don't even see C-4 listed under the possible transmission types. Oh well, live and learn.
Corpsman24
17
Aug 12, 2013 10:14 PM
smokinf1
Aug 27, 2011 04:19 PM
bartuitschaijk
Oct 29, 2009 12:44 PM
rowdyron
Engine Swaps
Oct 21, 2005 01:36 PM
lotsafords
Dec 15, 2003 05:34 PM
