Wheel bearings?
Old Jan 21, 2004 | 11:25 PM
BigMattXXL's Avatar
BigMattXXL
Angry Wheel bearings?
I've got a "moaning" noise that accompanies a "rubbing" feeling in the floorboards. Noise seems to be originating from front left wheel area while turning left (sometimes). Sound is much more pronounced while turning either way in 4WD.
Safe to say my wheel bearings need to be checked/replaced? Ford recommends repacking every 35K and I'm at 80K and I've never done it
I sure don't feel like doing this in the cold...
XXL
Old Jan 23, 2004 | 09:10 PM
Tptoe's Avatar
Tptoe
Is the noise associated with the turning of the steering wheel? In other words do you hear it when the truck in not moving? If so could be in steering/suspension.
I mention it because I had bad ball joints that caused quite a problem. Not sure if it is your case though.
Old Jan 23, 2004 | 10:30 PM
BigMattXXL's Avatar
BigMattXXL
I'm very sure it's not the steering system; I know that noise
It's definitely coming from the wheel hub area.
XXL
Old Jan 24, 2004 | 09:09 AM
buzzard's Avatar
buzzard
Matt, I've never done mine, but I know that the hub and bearing is an assembly unlike the 2WD's that have the bearings stuck behind the spindle nut. I think you have to remove the entire hub to replace (you might even have to replace the entire assembly). Might be worth a trip/call to the shop to find out.
Old Jan 24, 2004 | 10:59 AM
BigMattXXL's Avatar
BigMattXXL
LOL Now that I've "come out" and admitted that I prostituted my spark plugs out to a shop, everything "Might be worth a trip to the shop" for me
I'll look into it. Sometimes I miss my '93 Rodeo. Even if something had to be done, you didn't have to worry about it, 'cause it ran just fine
XXL
Old Jan 24, 2004 | 12:18 PM
tsdrallyer's Avatar
tsdrallyer
Matt,
Although my '97s bearings have made no complaints to date at 122K miles, it's not spent whole winters in snow country either. That said, other vehicles that did have bad or loose bearings made a whirring noise, not a rumble or rubbing sound, and the vibration never entered the cabin. I'd suspect the CV joints in front wheel drive or 4x4 vehicles. This can cause the sensations you describe and would be much more pronounced when turning. I once drove a Chevy a freind was thinking of buying and I was afraid it wasn't going to make it back to the used truck lot.
Old Jan 24, 2004 | 01:02 PM
jclarke2899's Avatar
jclarke2899
buzzard is right, you'd have to replace the whole assembly. From what you describe, it doesn't sound like your bearings either. Tsdrallyer said about CV joints, which could be possible, they normally make a clicking noise when turning not a rubbing one though.
Old Jan 24, 2004 | 08:53 PM
valu8or's Avatar
valu8or
Re: Wheel bearings?
XXL
Just take it to the same shop that did your plugs!!!!... slacker!!!!
Old Jan 24, 2004 | 09:48 PM
BigMattXXL's Avatar
BigMattXXL
Thumbs down Re: Re: Wheel bearings?
That's a bold statement coming from somebody with four whole posts...
XXL
Old Jan 25, 2004 | 09:03 AM
valu8or's Avatar
valu8or
Re: Re: Re: Wheel bearings?
XXL
Expy owners are a bold bunch.... me included.
I had to give you some grief for that one. When I first got my Expy I found this site and did some research about them. I even got you EOG. I guess It suprised me to see that you took your truck to a shop for plugs. (trust me, I am going to do the same thing... I just thought it was funny). Good luck with the CV or whatever the problem is.
Carl
Old Jan 25, 2004 | 07:44 PM
mechdeclined's Avatar
mechdeclined
I have an '03. Have 6000 miles. After the first oil change and tire rotation at 4500, I have noticed the same thing, although mine does not seem to be any more pronounced when turning. I will be taking it in soon and will let you know if they come up with anything.
Old Jan 25, 2004 | 08:14 PM
mechdeclined
ok
resq302
Aug 21, 2018 10:29 AM
YellowXLT
Feb 23, 2016 09:15 PM
kevb
Jan 10, 2016 09:00 PM
Shernius
1997 - 2003 F150
May 14, 2014 07:42 PM
96f15013ddie
Oct 10, 2013 10:04 AM
