brake light probs
Old Jan 21, 2004 | 08:39 PM
olblue3's Avatar
olblue3
brake light probs
Hi guys I got a problem with my brake lights on a 77 f350 rollback. prob is that when you put on brakes left light doesn't work but if you use left turn sig. it will blink and haz. will make it blink. I just did a cab swap with a 78 model because mine was to far gone to fix and had to use my column because the other was already removed. The harness for the 78 column has different colored wires than my 77 so now im lost as my 77 repair man.dosent show this color codes. Any help, I'm stumped!!
Old Jan 21, 2004 | 08:50 PM
ejustin3724's Avatar
ejustin3724
I had a light problem and ran a jumper wire to all the different points at the socket for a continuity test. Thus making my own diagram. Sorry that’s the best I can do.
Foamseahorse
Apr 14, 2014 11:22 AM
forge77
Electrical Systems/Wiring
Oct 15, 2013 04:00 PM
DGMFORD
Sep 22, 2013 09:07 PM
AmeriKen
Sep 27, 2004 08:44 PM
theonlybull
Nov 5, 2002 09:28 PM
