So much for the O2 sensor
Old Jan 21, 2004 | 05:47 PM
Bimmer ese's Avatar
Bimmer ese
Wow...it was soooo easy to change out. For one, didn't even warm up the truck. Sprayed a little rust eater, and wham...out she went. Also didn't know that Bosch made these little suckers for Ford.
On the other hand, the fuel filter was a pain in the a$$ to change out. Had to buy two different adapters for disconnecting the fuels lines from the filter.
I do have one question...replaced the PCV valve and noticed it had a little oil in it. What could be the cause of it? Also replaced the little filter inside the air box too. That thing was toast. Do you think the old, clogged filter could have been the culprut?
Cheers,
Dan
Old Jan 23, 2004 | 10:27 AM
gatesj's Avatar
gatesj
A little oil out of the PCV is fine, as long as it's not a lot. It's usually blowby and high rpms that send oil up through there.
jerbar
Aug 27, 2014 10:57 AM
KenRebF-250
Jun 9, 2013 09:46 PM
WVF150VIANC
1997 - 2003 F150
Jun 29, 2004 03:22 PM
dusty1
2004 - 2008 F150
19
Mar 13, 2004 04:49 PM
pilot10
1997 - 2003 F150
Mar 1, 2004 08:45 AM
