Loud, Loud, Loud!!!
Old Jan 22, 2004 | 07:20 PM
Cool1996's Avatar
Cool1996
go to www.mileliminators.com for o2 bypass
Old Jan 22, 2004 | 09:40 PM
93_F150's Avatar
93_F150
I run 3" single chamber flows on my Trans Am.... to be honest, you're better off without a muffler, it's jsut as loud!
Old Jan 22, 2004 | 09:55 PM
peppy's Avatar
peppy
The cross flow is the best idea. True duals run your exhaust as if it were coming from two 4 cylinder engines. The cross flow enriches the tone of your exhuast, and help keep the gas pressures equel so that your engine also runs like an 8 instead of two 4's. You dont need a true cross flow system. You can use a straight peice of pipe to connect your true duals. Try and connect the pipes as far back in the system as you can for a deeper tone. Although if you have money to burn, a true cross flow system does have its benefits.
Well, thats what I hear anyway, I make most this stuff up.
Old Jan 23, 2004 | 02:00 PM
akford351's Avatar
akford351
Just go with straight pipes from the manifolds back... put an h-pipe in there to balance out both banks. That'll be the loudest possible setup... unless you want to dump it just past the cab, then that'll be a bit louder.
Old Jan 23, 2004 | 08:24 PM
Cool1996's Avatar
Cool1996
thanks i'm going to go with either flowmaster 40 or glasspacks.
Old Jan 24, 2004 | 01:05 AM
Gregxlt's Avatar
Gregxlt
I just put straight pipe on my truck from the cats back and it sounds real nice. Has a nice rumble at idle but when u jump on it everyone knows. Only cost 100 bucks too....greg
Old Jan 25, 2004 | 10:59 PM
homerstud's Avatar
homerstud
just wack it all all off like i did on the bronco, run em' out in front of the back tires, and if your like my me the driver's side pipe will sound like a jake brake on a semi!!!!!!!!!!!!!!
Old Jan 26, 2004 | 10:45 AM
EPA's Avatar
EPA
Homerstud,
I suggest you restore your vehicle to original operating condition before I contact higher authorities. If you fail visual inspection you could face hefty fines and other penalties.
I suggest you read this article and others on the epa.gov site.
http://www.epa.gov/otaq/cert/factshts/catcvrts.pdf
Old Jan 26, 2004 | 12:11 PM
f100guy's Avatar
f100guy
woo is this dude for real is this a real EPA agent ahhhh we're all gonna go to jail i have a 91 5.0 tbird with all 3 cats gutted and 1 resonator with 2 flowmaster 50 series what ya think about that. but now it is not running. the tranny went out
Old Jan 26, 2004 | 12:28 PM
EPA's Avatar
EPA
Further provocation will result in stiffer penalties.
I have contacted Mike Leavitt, 10th Administrator of the US EPA. Generally Mr. Leavitt is not as kind and forewarning as I am. He will see to it that your IP address is traced and your exact location identified. Sorry, but you are in a world of hurt openly posting about performing illegal actions. (This is all archived, so there is no chance erasing your online identity will protect you)
Remember, anything you say can and WILL be used against you in a court of law.
Old Jan 26, 2004 | 01:52 PM
grapegravy's Avatar
grapegravy
Don't you have to be arrested first for that line to take effect or has the EPA also gutted the Miranda Act. Please be careful threatening people with legal action from posting on a website. And yes,, you can trace my IP as well. I have nothing to hide. No, I don't have cats (that go on a vehicle, that is) and never will
Old Jan 26, 2004 | 01:59 PM
f100guy's Avatar
f100guy
hey you did not catch us in the act of driving a car or truck that is supposed to have cats but does not so you can't do anything. and also i said the car is not running so i did this while i have the motor out which has been over 1 month. i have not an the car without the cats yet and probably won't since i have no money. but yeah anyway you did not catch me driving it without cats.
Boss949
2009 - 2014 F150
22
Feb 11, 2013 10:30 AM
maticuno
Exhaust Systems
May 2, 2005 07:35 PM
ddogg126
Exhaust Systems
Dec 31, 2003 12:06 AM
OldBlue67
Exhaust Systems
17
Sep 3, 2003 08:30 AM
weldman
Exhaust Systems
Mar 28, 2002 11:11 AM
