Offroad & 4x4
tow hooks
Old Jan 21, 2004 | 02:05 PM
frdcowboy's Avatar
frdcowboy
tow hooks
hey.just bought a 94 350 and i need to put tow hooks on the front so when i get stuck in the mud. I was thinkin bout just drillin holes in the frame and installin them that way. Has anyone tried this or is there any other suggestions. Thank you.
Old Jan 21, 2004 | 02:34 PM
JeremyH's Avatar
JeremyH
Just please, Oh PLEASE dont weld them on. If you are gonna drill a hole in the frame, then it would be best to weld a sleeve in there and then run the bolt through. Use at least two bolts for each hook.
Old Jan 21, 2004 | 03:11 PM
KJKozak2's Avatar
KJKozak2
Stay away from the little chrome or black jeep hooks that you find everywhere. They're strong enough and everything, but they're just too small to get a decent strap on. The retainers are pretty useless, too. I've destroyed 2 good straps with the ones I had.
I ended up getting a pair from a swap meet that were off of a gm truck. Thet're about 10" long with a 5" dia. hook. I'm mounting them vertical like a "J" so the strap hangs from them when it's loose.
Kevin K.
Old Jan 21, 2004 | 05:20 PM
Ryan50hrl's Avatar
Ryan50hrl
theres a picture in my gallery of a solution for tow hook mounting points....feel free to email me for more info.
Old Jan 21, 2004 | 06:40 PM
fishmanndotcom's Avatar
fishmanndotcom
ahhhhh...no more tow hooks! get a couple of shackles:
http://www.rockstomper.com/catalog/r...y/shackles.htm
or:
http://www.mytscstore.com/detail.asp...productID=2373
these aren't the exact ones but it gives you the basic idea....I have a set on the front of my truck (check my gallery) and they have been abused and have held up impressively!
tow hooks have a bad tendency to bend out b/c it has an open end...i suggest (from experience) get something enclosed!
-Jason-
Old Jan 21, 2004 | 09:41 PM
JeremyH's Avatar
JeremyH
I like most of Rockstomper's stuff.....except for those tabs. These are an item that deserves to be double welded into a bumper.....not welded only on the front.
Old Jan 21, 2004 | 09:46 PM
proeliator's Avatar
proeliator
I recomend shackles as well. Can be found online or at your local logging supply outfit. Mine are rated at 10 tons
fidel.medrano
Dec 22, 2016 03:25 PM
ryno_rx8
Oct 27, 2012 09:10 AM
greg213187
Mar 2, 2010 06:08 PM
RogueSpear2023
Aug 19, 2007 08:53 PM
Matt M, PA
Sep 12, 2005 01:34 PM
