Headlight switch replacement and starting problems
Old Jan 20, 2004 | 11:05 AM
supercab blue's Avatar
supercab blue
Question Headlight switch replacement and starting problems
This is my first time posting here, so here goes. I have a 1992 Ford F-150 supercab. The headlight switch **** came off the shaft and I couldn't find a way to glue back so I bought another one from the dealer. I would like to find out how to replace the headlight switch on this truck. Also, every morning for the past 8 months, the truck has had trouble starting up right away to the point that it stalls after startup. Then I have crank it again and give it some gas so it doesn't die out. What could be the cause of it? By the way, the fuel filter has not been changed for 2 years. Your responses are greatly appreciated. Thank you.
