pop
Old Mar 11, 2002 | 08:53 AM
larry derouin's Avatar
larry derouin
pop
Old Mar 12, 2002 | 12:23 AM
Ryan50hrl's Avatar
Ryan50hrl
pop
Ok...my truck makes a wierd noise and i'm wondering if anyone else has had the same one. When in reverse and moving backward, like backing out of a parking stall, i hit the breaks and my truck makes a wierd pop,,,its quite loud. As soon as i hit the brakes going forward it does it again and then won't do it again till i back up again. I can't find anything loose so i'm at a loss.
Ryan
Old Mar 12, 2002 | 12:32 AM
kings51's Avatar
kings51
pop
what kinda truck? how is it configured?
Could be the rear brake shoes rolling forward or back when you apply the brakes. Check their adjustment....as well as all the hardware associated with the rear brakes and shoes. Bendix self adjusting brakes (drum style) frequently go wacko and can make all kind of noise when the cables break or the system is not adjusted properly.
Good luck.
Old Mar 12, 2002 | 12:37 AM
Ryan50hrl's Avatar
Ryan50hrl
pop
Its a 95 F-150, it kinda sounds like its coming from the front.
Ryan
Old Mar 12, 2002 | 12:22 PM
brett_d's Avatar
brett_d
pop
Check your transmission/engine mounts. A common occurance for the 88-96 fords is for the transmission bolts to work themselves loose from the crossmember. Causing a Pop or Clunk when hitting the brakes or accelerating!!!
Old Mar 12, 2002 | 12:30 PM
wesmansr's Avatar
wesmansr
pop
My '93 F150 ext cab does the samething. Mine does it when backing out of my driveway turning the wheels. Sounds like its something binding, then letting go & poping maybe steering related.
Old Mar 12, 2002 | 07:07 PM
mickelsons's Avatar
mickelsons
pop
my 96 has done that also normaly after sitting over night and when i go to back up it binds up then pops and never have a problem from there I just asumed my brakes were sticking or somthing.
Old Mar 12, 2002 | 07:29 PM
Ryan50hrl's Avatar
Ryan50hrl
pop
Thats exactly what mine does. It does it when turning and backing. If anyone can figure it out let me know. I'm fairly sure its not my brakes, they're completly new.
Ryan
Old Mar 12, 2002 | 08:25 PM
restorit's Avatar
restorit
pop
There were a number of posts a while back that discussed the odd tendency of the front wheels to lean inward at the tops (can't remember if that's excessive camber or caster?) on Ford trucks when backing them up. Some considered this to be a sign of worn ball joints while others theorized that it had to do with the weight transfer that occurs when backing up (additional weight being placed on the front suspension). I wonder if this isn't related. Could it be ball joint play, or tie rod ends? I wonder if there's a common element to your problem, for example, do you all have a few miles on your suspension components? When was the last time the front end was greased?
Old Mar 12, 2002 | 10:23 PM
dewey_gubbels's Avatar
dewey_gubbels
pop
check you front brake calipers. mine broke off the brackets and had to be welded again. i had similar problems
Old Mar 12, 2002 | 11:37 PM
Ryan50hrl's Avatar
Ryan50hrl
pop
Ok,,,first one. New ball joints 6000 miles ago. Those were my first thoughts. Greased twenty miles ago. All the front end parts are new. Second one. I checked the brake calipers and the brackets in which the bolt. All is good.
Ryan
Old Mar 13, 2002 | 06:10 AM
Ski's Avatar
Ski
pop
I have a 92 F-150 4x4 and have been chasing after this problem for some time. I put new ball joints in, coil springs, shocks, tie rod ends, drag link and I'm fixin to change out the pivot bushings. it's just one of them noises that drives me crazy. Ball all over the truck and found no loose mounts either. If you ever resolve your noise I would appreciate it if you could le tme know how you resolved it, thanks
Ski
Ski46100(No Email Addresses In Posts!)
Old Mar 13, 2002 | 10:10 AM
Ryan50hrl's Avatar
Ryan50hrl
pop
Let me know how the new pivot bushings work. That was going to be my next attempt too. But if it doesn't fix it for you i probably won't.
Ryan
Ryan50hrl(No Email Addresses In Posts!)
Old Jan 20, 2004 | 12:51 PM
christop43's Avatar
christop43
Ryan50hrl
Did you ever find out what the problem was? My 90 Bronco is starting to do the same thing while in reverse.
Old Jan 20, 2004 | 01:34 PM
jesse460's Avatar
jesse460
check the radius arm bushings my 95 popped when i would back up then hit the brakes the bushings looked ok but when i took the radius arm out the bushing was all wallowed out inside and the radius arm was hitting metal to metal on the bracket.
