Intermittent wont start
Old Jan 20, 2004 | 06:23 AM
peppy's Avatar
peppy
A few weeks ago, truck wouldnt start, jumped it and fine for two weeks or so. Then last week wouldnt start again. Thought maybe loose ground. Not the case. I chased a bunch of wires, turned out that a + cable to the soleniod had broken at the wire loop. Fixed the broken wire. Seemed to have fixed it. Then went to start, no go. Took wires off, back on, started fine. Then wouldnt start again.
When it doesnt start......move the key to 'on' and the fuel pump runs, turn to 'start' amd the volts drop to zero, the pump stops and the dome lights off.
Try again, might or might not start. Battery does not loose its charge. Removed the - battery cable while running, kept running,therefore no charging problem.
I thought of 2 possibilities........
1. Soloniod is going bad.
2. Ignition system somewhere is faulty.
What do you think? What to do next?
Thanks
Old Jan 20, 2004 | 06:49 AM
Bob Ayers's Avatar
Bob Ayers
Just a word of advice, DO NOT remove the battery cables while the engine is running!!!!! The battery acts as a filter for voltage spikes from the alternator. Removing the battery cables can also create a huge Di/Dt, resulting in a huge voltage spike that can damage anything electronic, like PCM, etc.....
Old Jan 20, 2004 | 07:05 AM
peppy's Avatar
peppy
I'll take your word for it. Di/Dt?
Old Jan 20, 2004 | 09:55 AM
Franklin2's Avatar
Franklin2
"Took wires off, back on, started fine. Then wouldnt start again.
When it doesnt start......move the key to 'on' and the fuel pump runs, turn to 'start' amd the volts drop to zero, the pump stops and the dome lights off."
Bad battery cable or corroded connection at battery. Check the + and the -, at the battery and the connection at the block and starter relay.
Old Jan 20, 2004 | 09:23 PM
peppy's Avatar
peppy
At this point I'm just tracing every wire I can get ahold of and taking it off, cleaning it up and putting it back on. Its gonna take a long time to get to them all. I figure its preventive for the next problem as I go along. But then, when I find the problem, I'm sure that I'll be done with wire cleaning.
But then, I did find some things this morning that might have contributed.
meier63
Dec 24, 2014 10:04 AM
taznn
May 26, 2013 10:06 PM
MyName1sMud
39
May 11, 2012 09:41 PM
airharley
Apr 15, 2011 07:05 PM
ihateminimumwage
Electrical Systems/Wiring
149
May 10, 2007 08:35 PM
