1978 - 1996 Big Bronco
Tire/Wheel size advice
Old Jan 20, 2004 | 06:02 AM
sdrowand's Avatar
sdrowand
Will 33X12.5X15 tires fit on a 1996 stock rim? I know a lift is i order i just wasent sure if i needed new wheels as well. I like the stock rims. Also will a 2inch lift be sufficient for moderate off-roading. thanks for imput.
Old Jan 20, 2004 | 08:03 AM
joebronco94's Avatar
joebronco94
Should be fine I have 33x12.50x15 on stock rims and stock Bronco . It depends on tire maker if you will rub.
Old Jan 20, 2004 | 08:17 AM
pezley69's Avatar
pezley69
I think you can squeeze that tires on the rim, but that is a wide tire for that rim. I would recommend getting some new wheels and you can get a diff. backspacing to eliminate the rub on the inside of the wheels. I bet the tire company will recommend a ten inch wide rim with those 12.5 inch wide tires. I think you will need at least 2 inches of lift for 33's. I have 31's on my '96 and I think I could go with 32's no problem, but that is all without rubbing. I ordered a set of wheels and tires (BF AT KO's and rock crawler powder coated wheels) when I got mine. I hated the stock wheels (I have an XL) as they were ugly.
Hope this helps.
Old Jan 20, 2004 | 07:40 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I have 33s on my bronco now and no lift. You will want to get at least 10" wide wheels for 12.50" tires or you will risk spinning the tire off the rim while offroading.
Old Jan 21, 2004 | 10:13 AM
burntPiston's Avatar
burntPiston
33x12.5 fits fine on the '96 7.5" wide wheel. I have run that setup for 2 years on and off-road.
Old Jan 21, 2004 | 12:17 PM
Kemicalburns's Avatar
Kemicalburns
Broncoroadkill, having a wider rim will cause the tire to spin of much easier then a narrower rim especially when they are aired down. 8 inch rims would be minimum width for that wide of tire but like burnt piston said 7.5's can and have been used before. also running 33's on your year bronco will require you to shim out your front bumper 1-2inches to keep the tire from rubbing. but when you offroad they will rub for sure unless you lift the truck 4"s
good luck
Old Jan 21, 2004 | 05:29 PM
Broncobigtire's Avatar
Broncobigtire
I have a 92 with the 15x6 rims...if i want to run a 12.5 wide tire will i need a different backspacing and if so what should i get or how do i figure that out...thnks
Old Jan 21, 2004 | 05:30 PM
Broncobigtire
*** that is on new 15x8 rims...what backspacing
Kemicalburns
6inch rims didnt think broncos came with such a narrow rim . are you sure about this?
Old Jan 21, 2004 | 07:07 PM
Broncobigtire
yes thats what it says
Old Jan 22, 2004 | 12:22 AM
BroncoRoadKill
You sure about that, I thought the smallest rim ford made was 7"
Unless you have rims that came off a 50s model truck.
Old Jan 22, 2004 | 08:35 AM
Broncobigtire
Yes that is what is on the door sticker and stamped onto the inside of the wheel
Old Jan 22, 2004 | 08:37 AM
Broncobigtire
again what backspacing should i get for my new wheels (15x8) coming from 15x6
Old Jan 22, 2004 | 09:39 AM
Kemicalburns
i believe 2.5 but not 100% on that
Old Jan 22, 2004 | 10:23 AM
pezley69's Avatar
pezley69
I would ask the place you plan to buy your wheels from. They will be able to look up your current backspacking and make a suggestion with your new wheel/tire size. I wish I could remember the backspacing on the wheels when I ordered mine, but I dont remember.
Good luck.
ManfredVonRichtofen
16
Sep 14, 2012 09:16 PM
Deputy6667
Nov 14, 2010 10:03 PM
Scoop531
Apr 9, 2007 02:13 PM
Trav460
Jan 26, 2007 08:42 PM
69ford99
Apr 24, 2006 08:53 AM
