Dana 60 diff oil amount needed
Old Jan 19, 2004 | 07:00 PM
ceetwarrior's Avatar
ceetwarrior
Question Dana 60 diff oil amount needed
Hey, can anyone look in the their shop manual and tell me how much fluid a 1967 Dana 60 Limited Slip axle holds? Thanks!
Old Jan 19, 2004 | 11:19 PM
MudinMan19704x4's Avatar
MudinMan19704x4
just put it in untill it starts pooring out..........then put the bolt in...thats how the pros' do it......
Old Jan 19, 2004 | 11:22 PM
ceetwarrior
Ok, sounds good to me MudinMan. I should have just asked my pops this question first off. 80-90w limited slip gear oil should be fine right?
Old Jan 19, 2004 | 11:28 PM
MudinMan19704x4
did you put the lube for LS in there? and yea that sounds fine......the more fluid the better means, better lubed and cooler the parts are.....just go till it poor (messy) and you should be fine......
Old Jan 19, 2004 | 11:35 PM
ceetwarrior
MudinMan, yeah the lube I have is LS. My dad said to jack up the rear end really high, so no more oil will leak out so when I put gasket material on it its perfectly clean so it doesn't leak.
Old Jan 19, 2004 | 11:38 PM
MudinMan19704x4
yea.......either way the more fluid the better and the better seal well...the better........
thewestie
43
Jul 21, 2014 07:50 AM
Plowingking
Dec 3, 2013 06:37 PM
robjs111
Nov 12, 2013 07:14 AM
Waxy
Oct 18, 2010 11:32 PM
Offroad & 4x4
25
Jan 23, 2003 02:04 AM
