I don't know, but be careful with aftermarket wheels.
Crawl under your truck and take a look at the inside of the front wheel. The brake line connecting to the caliper and the lower ball joint stud have only a few millimeter's clearance to the wheel.
Backspacing is the offset I believe. Its the amount of wheel that extends either under the truck (positive offset) or outside the vehicle (negative offset). Deep dish wheels would have a negative offset in that all the weight would be distributed outside the vehicle where the dish is as opposed to under the vehicle as a positive offset as the manufacturers recommend. Also this is the clearance during normal operation, turns and bumps to ensure your wheels/tires dont rub or impact anything.
