2000 Explorer XLS Front Differential Leak
Old Jan 19, 2004 | 03:18 PM
JLB's Avatar
JLB
Hi All.
I've got a slow leak on my front diff. I haven't checked yet to see how much fluid it needs, but lets assume it is low. (I've only owned it about 6 mos, and I doubt it just happened to start leaking now.)
I'm not a stranger to replacing a gasket, but I've never done a differential gasket, so here's what I don't know:
Fluid: I assume I can just walk into a Ford parts counter and tell them what year and model I have, and walk out with the right stuff. But is there anything else I should know?
Top-off: Is it worthwhile to pull the plug, top it off, and snug the bolts to try and stop the leak? Any chance this will stop it? Any dangers in pursuing this as my first pass at fixing it?
Replacement: I haven't looked that close, but I would GUESS that if I can get the bolts off there shouldn't be too effort involved to replace this gasket. Any hidden difficulties if that is what I decide to do?
Thanks,
Joe
Old Jan 19, 2004 | 05:58 PM
maa139's Avatar
maa139
I just changed the axel seals in my 94, and there was no gasket. Just a sealant. I don't know if the difference in year or the front/back matters, but that was my experience.
Old Jan 20, 2004 | 06:14 AM
JLB's Avatar
JLB
Assuming our designs are similar or the same, is it a 2 hour job, a weekend job, 4 hour job? Any unusual tools? It looks like it would be pretty basic, but looks can be deceiving...
Thanks,
Joe
Old Jan 20, 2004 | 04:24 PM
maa139's Avatar
maa139
If you only have to take the cover off, clean the surfaces and put it back on, it's probably an hour or two depending on your level of expertise. Only basic tools are necessary. A wrench/ratchet to get the cover off, a pan to drain the gear oil into, rags, clean putty knife to clean the surfaces, silicone sealant and new gear oil.
Old Feb 2, 2004 | 09:09 PM
JLB's Avatar
JLB
Thanks! I was away for awhile, so didn't see your response until just now. I appreciate the help!
Joe
Old Feb 5, 2004 | 10:58 AM
Sanford3's Avatar
Sanford3
Joe, hold on a minute before yanking the cover off. I had to take my tranny apart to get the clearance required to yank mine off. I have a '96, and what should have been an hour job turned out to be quite a bit longer. Just make certain you can clear the entire case before starting - unless you have a back-up vehicle to drive. Otherwise, it is a quick scrap the sealant off, apply new goo, and bolt the puppy back up.
Good luck.
k_bo
Jul 29, 2016 12:58 PM
Joeblowv1
Mar 16, 2016 09:32 AM
badger2196
Mar 16, 2015 05:10 PM
fred_79f250
May 20, 2012 04:16 PM
53redford
37
Apr 25, 2007 08:58 PM
