Sponsored by: Real Truck
Leveling kit
Old Jan 19, 2004 | 03:11 PM
slammer's Avatar
slammer
Leveling kit
I plan, tenatively, on gettting a new F350 CC... and dont like the way the rear sits so much higher than the front. My questions are:
1. Will a 2.5" leveling kit on the front fix that?
2. Will the "leveling kit" make the front end higher than the rear end on level ground? ( I HATE that look)
Thanks... gonna order it on 2-14... rebates went up to $2500
Old Jan 19, 2004 | 03:25 PM
DCSpecial's Avatar
DCSpecial
The amount it takes to level out the front will depend on the motor you choose and the code springs that it comes with stock.
If you get the snow plow package it might not need a leveling kit........but if you get lesser rated springs and a PSD it might require 3" to level.
If the front does end up higher you could swap out to a bigger rear block.
Hope this helps.
Old Jan 19, 2004 | 03:35 PM
02superstroker's Avatar
02superstroker
Originally posted by DCSpecial
If the rear does end up higher you could swap out to a bigger rear block.
You mean front?
In most cases the 2.5 would work.. but if you don't get the plow package and you have the psd likely you will want a bit more. Say 3.5". If all else fails, upon delivery of your truck you could just measure from hub to top of fender to see what the difference is front to back...
Old Jan 19, 2004 | 03:53 PM
DCSpecial's Avatar
DCSpecial
Originally posted by 02superstroker
You mean front?
Yes, I did mean the front and corrected my first post .
Guess it helps if I read the post after I type it .
Old Jan 19, 2004 | 08:14 PM
nolife's Avatar
nolife
mine sat real low compared to all others I saw. its a 2002 3/4 ton psd. i used a pro-comp 3' leveling kit. and it raised the front more than the rear. we added a inch block in the rear, now its good
Old Jan 19, 2004 | 10:51 PM
jamesfx4guy's Avatar
jamesfx4guy
i want what i want (f350 sport- crewcab PSD w/ FX4 pkg)
but i want it level......
will the pro-comp 3 inch leveling kit do the trick?
and where do i get the one inch block for the back?
and does this just sit atop the existing 4 inch ones there? also, where do i get the procomp kit?
thanks
Old Jan 19, 2004 | 11:26 PM
02superstroker
James - Yes that 3" kit will do the trick.
As far as the rear block, you can get one at any 4x4 store.. but you might want to instead of adding a block just replace the existing block with one that is 1 inch taller. This is safer, and has a lesser chance of the block actually coming out. Spend a little to save alot kinda thing. just a thought - good luck
Old Jan 20, 2004 | 12:58 AM
Bigblacktruck's Avatar
Bigblacktruck
Hey you guys can save alot of money by short cut I found. I've got a 2000 v10 ext cab camper/snowplow/lariet package on mine.
They are 3" wide spring packs right, go in Summit racing and buy the 3" rear add'a'leafs. There will be a longer side to the leaf.
Take a air zip wheel and cut about 3" off the long end and install it on the bottom of the factory pack. It will have a bit of space between the pack and you will have to use a C clamp to put the U bots back on . I have had mine on for two years and they have not saged even the slightest bit. Gone offroading with ten people in the truck and have a 1000 pound western 8 1/2' V plow on it as I am typing and have had zero problems. $40 from summit racing Thats all it took.
Old Jan 22, 2004 | 07:55 PM
02superstroker
Big Black Truck.. you did put a new center bolt on those leafs.. right?
Old Jan 23, 2004 | 12:13 AM
Bigblacktruck
Yeah the I had some lying around from another lift I had done.
It was actually fairly easy the only thing I would do different is not to compleatly disconect the axle and do only one side at a time. If it is done you need a comealong or a winch to get it back in to its seat.
Old Jan 23, 2004 | 06:48 AM
02superstroker
Thats good - - i was just makin sure cause in your previous post you said you had to use the c-clamps to get the u-bolt back on, i was hoping you didn't forget the center bolt.. that wouldn't be good lol
Old Jan 23, 2004 | 09:40 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
I asked this of FabTech and they never answered so I'll get it from actual users:
Does installing a leveling kit make your truck more apt to squat under load (or at least appear to be squatting)? The way they come from the factory, they pretty much get level when under load (i.e the rear end squats to be level with the front.)
Raising the front should shift more weight (of the truck) to the rear. That, and if front and rear start out level and you load the rear then it seems to me that the rear HAS to end up lower than the front. As much as I like the look of a level truck, I hate the look of a "squatting" truck even more.
Having said that, I notice that I see alot of Excursions squatting down the highway under load, but I really haven't noticed any trucks (250 or 350) doing this. Maybe the truck springs are strong enough that unless you load close to max capacity, they won't really do this?
Any comments? (If any of that even made sense)
Scott
Old Jan 23, 2004 | 04:48 PM
mhagen's Avatar
mhagen
I have installed the leveling lift on mine and have pulled my 21' boat and it does not squat at all. I would definately recommend the leveling lift
Old Jan 23, 2004 | 05:09 PM
thump96's Avatar
thump96
Mhagen,
That Edge pack is a 2" pack right. Do you get any any tire rub on your springs. I have been told 315's would work and then that they would not work. This was on a F250 though. What do you think? Is your F350 perfectly level. Do you know how high it measures out to be?
Thanks
Old Jan 23, 2004 | 05:14 PM
thump96's Avatar
thump96
mhagen,
Oh by the way.....Damn nice truck!!!
