Fuel milage
Old Jan 22, 2004 | 08:08 AM
Ian cate's Avatar
Ian cate
I made an appointment to get it checked out.I drive half interstate half secondary roads 7 miles each way to work and I am using over a gallon a day.I go the speed limit and do not gun it.With the price of cheap gas nearing 1.70 in my area I can't afford to keep it if that is all I will get.My old four cylander ranger got 25 average with the same driving conditions.My 98 has less than 30000 on it and the mileage sucks.
Old Jan 23, 2004 | 06:51 AM
seangoodwin's Avatar
seangoodwin
I'm getting about 18 to 19 (around 17 when it's cold). And I drive almost 50/50 local and interstate.
Fuel mileage improved after 2 tanks of Chevron Techron and 1 tank of Mystery Oil (MMO). The MMO also got rid of the last of my engine knock and I'm back to running 87 octane (low grade).
I also wonder if folks are calculating correctly. I try to fill up at exactly the 1/4 tank mark. Then I record the gallons that I put in and when I go to fill up the next time (again at 1/4 tank) I write down my tripometer reading. The gas gauge is just too inaccurate when you get down near the empty mark. My "low fuel" light comes on with about a 4 gallon 'reserve'.
Old Jan 23, 2004 | 07:40 AM
Ian cate's Avatar
Ian cate
I put fuel in when it was down to half a tank.I had written down the miles on the odometer when I got fuel the last time and subtrac. the mileage and divided by gallons it came to 13.25.
The specs say I should be getting a min of 17 and a max of 27.
Old Jan 23, 2004 | 01:07 PM
dziner92821's Avatar
dziner92821
93 XLT, I DON'T BABY MY TRUCK AT ALL AND AS A RESULT I GET AROUND 200 MILES PER TANK.
MY DAUGHTERS F150 GETS BETTER MILEAGE.
Old Jan 23, 2004 | 05:02 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Hey that was 99ranger i am 99xlt lol
I get 18 MPG on mine combuned 50/50 driving, and that was after fourwheeling several times. To calculate my mileage, i fill it up and record the odometer reading. Then i drove for about 1000 miles and wrote down how much gas i added everytime. Then i filled up the last time. Added up all the gallons i used. Then divided the miles but the gallons. 18.3 is what i get.. Probably better if i drove it easy. And my truck has 65k on it. The last owner didnt mainatin it at all except change the oil (at a garage) I get 350 miles per tank. (18.3 times 19 if you want to check)
And BTW a chip doesnt help mileage at all , in fact it hurts it. I can give you the link so you can read it for yourself, but all you have to do is go to where you bought your chip from and read the fine print.
Old Jan 24, 2004 | 03:24 AM
Houckster's Avatar
Houckster
Lightbulb It's the driving . . .
My take on your mileage is that there is a large percentage of the time you are driving when the engine is warming up and, therefore, running rich. If your commute distance was 14 miles, say, rather than 7, your mileage would be noticeably better.
A 7 mile commute doesn't even give your engine time to burn off the water a cold start creates. This is severe duty driving and hopefully, you will change your oil accordingly.
Worth considering: Ford makes a coolant/battery heater ($65-70) for your engine. If you can park near an outlet, using it will help you considerably reduce the warm up time for the engine and the consequent water that forms in the oil.
Old Jan 24, 2004 | 11:34 AM
99xlt4.04x4
Yeah that is a problem.
Also your oil in the rear-end and tranny doesnt have time to warm up and it is thicker (Harder to turn the tires).You could let it warm up before you drive to work, but that would burn gas sitting there. It might be better on the engine though.
