Another weird Ranger noise
Old Jan 19, 2004 | 02:29 AM
Ranger2000's Avatar
Ranger2000
Hi folks,
2000 3.0 FFV 5 speed 4x4 Offroad 43,000 miles
I have another weird noise that hopefully someone has had/seen/heard of, etc.
Recently (especially in below zero weather) when I am driving and my temperature gauge is approaching normal I hear a high-pitched whining noise from probably around the transmission, but I can't be sure. It might actually be anywhere in the engine or under the truck.
When I either 1) hold the gas constant and push in the clutch or 2) just let off the gas the noise stops and goes away and does not come back.
It only has happened as the truck is warming up - it never happens while the truck is cold and never after it gets really warm.
The part about letting off the gas or pushing the clutch in leads me to believe it is transmission or driveshaft because they would slow down or disengage when I do those things. Maybe something is out of sync or something? I have the steel driveshaft, not aluminum.
It could be lots of stuff but the part about it only happening as the truck approaches normal operating temperature (and not before and not after normal operating temperature) might be a valuable clue.
I don't experience any loss of power or decresed performance when the noise happens - I just let off gas or push in clutch and it is gone - but man it is annoying and frustrating.
I already have the serpentine belt noise and had the door ajar thing and now this.
Thanks in advance
Old Jan 19, 2004 | 05:49 AM
Bob Ayers's Avatar
Bob Ayers
Another common problem is a noisey IAC valve, and they make a noise somewhat like you are describing. You can try cleaning it first, but most of the time, they have to be replaced......
Old Jan 19, 2004 | 05:57 AM
brianjwilson's Avatar
brianjwilson
The IAC valve should only be making noises when it's idling. Don't think it would be the cause of trouble when at higher RPMs, but I could be wrong. On the other hand, It doesn't hurt to clean it
Old Jan 24, 2004 | 02:45 AM
Ranger2000's Avatar
Ranger2000
To clarify, the best way I can describe the noise itself is it is like the whistle from a teapot
Old Jan 24, 2004 | 12:30 PM
el conquistador's Avatar
el conquistador
I have that problem too but I always thought it was exhuast pipe or the muffler but i could be wrong.
