What's behind your FE???
Still tweaking on my project, contemplating stall converter/rear gear changes and it would help me a lot to see what all of you are doing, and hopefully it'll help someone else in making decisions beforehand...
I'm mainly interested in what converter you're running with your C6, but it would be very helpful if you would please list the following specs:
1) Cam - Brand, duration and lift @.50"
2) Rear gear ratio
3) Torque converter - Brand, part number if available, and advertised stall rating.
2) 3.70 with mini spool
3) Stock converter modified by trans builder to stallat 2,400 rpm behind the 360 but with the 390 it stalls at 3,200 rpm. I have a 3,800 10" converter in the shed that is going in pretty soon.
2. Dana 60 with 4.10:1 gear ratio, open but soon to get some form of street friendly locker.
3. Modified stock style converter, stall speed not increased as far as I know. I'm actually not sure what was done to the convert. But I like the way it runs. I just told "Zeek" when he was rebuilding my C6 that it would probably see some healthy HP/Torque. He replied "Awrighty, I'll hook you up". ?????
1. Cam: Ford 360 stock, lift .427" intake, .431" exhaust, unknown duration, couldn't be that much
2. 3.70:1
3. Ford stock torque converter, I think it stalls somewhere around 1800rpm
Here's what I'll be running after I get the 390 in next summer:
1. Cam: Crane 343941, lift .533" intake, .563" exhaust, 272/284 duration
2. same 3.70:1
3. Same Ford stock torque converter, it's going right back in after the transmission.
A light foot helps. If I drive it hard, the mileage goes down.
A light centrifugal advance spring is installed, giving it a quick curve and more advance at highway speeds. The installed and working vacuum advance also helps.
I have quality blue streak points installed.
I use an Accel Super Stock coil.
I use premium plug wires, with platinum plugs.
I have the initial timing set at 12 deg. BTDC.
I use #68 jets in the primary, and #74 in the secondary, with a 6.5"Hg power valve. I keep the carb cleaned often. I'm thinking of changing to 67's on the primary and 75's on the secondary to squeeze that last little bit out of it.
A clean air cleaner also helps.
Making sure the brakes are not dragging is essential.
Sorry for the long post.
Edit: Note that synthetic fluids are NOT part of the formula. And dont tell me I'd get 17mpg with them!
I can be going down the highway on flat level ground with no wind, at 55mph, and have 18"Hg on the vacuum gauge. I barely have to hit the gas to keep it going!
Same here! my foot acually hurts from the steep angle i have to hold my foot.
