which first, exhaust or programmer
Old Jan 19, 2004 | 04:44 AM
spitball's Avatar
spitball
I was looking for some ops on order of upgrade. Exhaust first or programmer/chip?? Thanks
Old Jan 19, 2004 | 06:28 AM
powerstroker250's Avatar
powerstroker250
Gauges, intake, exhaust then the programmer/chip.
Old Jan 19, 2004 | 06:30 AM
Stinger_916's Avatar
Stinger_916
I have been thinking about this very topic my self and all the research I have done point to gagues first. You need to get some base line reading with the truck being stock this way you can tell if the other mods you do have a positive or negitive effect on your trucks preformance. If you don't want to install gauges then I would say bigger exhaust along with open air filter to let the motor breath more.
Old Jan 19, 2004 | 12:44 PM
bender97f250's Avatar
bender97f250
4" exhaust- high flow intake- guages then a chip or programmer.
Old Jan 19, 2004 | 03:35 PM
Quadzilla's Avatar
Quadzilla
Powerstroker250 said:
gauges, intake, exhaust then the programmer/chip
They're both right. Regardless of the order you do the first three, the programmer or chip comes last. Get the things that control/measure heat before you get the thing that creates heat.
Old Jan 21, 2004 | 04:47 AM
spitball's Avatar
spitball
Thanks for the information. I am still in between whether to upgrade with the issue being wear and tear on the vehicle. Are there any opinions on this?
Old Jan 21, 2004 | 04:56 AM
Quadzilla's Avatar
Quadzilla
Wear and tear on the vehicle is a result of driving habits. With all my mods, I'm not shortening the life of my engine unless I drive abusively, and you don't need mods to do that.
Old Jan 21, 2004 | 06:55 AM
stroken38s's Avatar
stroken38s
I first did the guages then programer. By having the guages I found that when I put the programer on with the stock exhaust I was having to high of exhaust gas temp, so I had to put the exhaust on being that I was actualy loosing performance.
Old Jan 21, 2004 | 07:29 AM
spitball's Avatar
spitball
Good point Quadzilla,
f250geier
Modular V10 (6.8l)
23
Sep 20, 2016 09:25 PM
Cold One
6.7L Power Stroke Diesel
Jan 30, 2012 09:06 PM
stroker_8
Nov 18, 2009 07:54 PM
stroke25
Aug 7, 2007 04:39 PM
Customz
6.4L Power Stroke Diesel
119
Jun 16, 2007 01:19 AM
