no start need help
Old Jan 18, 2004 | 11:26 PM
jandjstewart's Avatar
jandjstewart
no start need help
pI just replaced the motor in my 88 4 by4 ranger its a 2.9 multiport fuel injection. I put this motor in after i went through it and put new gaskets and bearings in. Now that its in it wont run, it acts like it wants to and trys to fire, i have both spark and injector pulse but the longest ive managed to keep it running was about 15 seconds and then it stalled out. I've tryed adjusting the timing and replacing the ignition module but still im no better. The motor has good compression and get 40lbs(or psi i forget, but it has what its suposed to) of presure to the fuel rail and the regulater is still good. I dont know what else to change or check if you have any suggestions please help.
Old Jan 19, 2004 | 06:04 AM
ol yeller's Avatar
ol yeller
chech your voltage, those won't run on less than 12 v
Old Jan 19, 2004 | 07:48 PM
Ken00's Avatar
Ken00
Did you pull the spout when you adjusted the timing?
