Sponsored by: Real Truck
stuck transfer case in low range HELP ! !
Old Jan 18, 2004 | 07:50 PM
Bossman7121's Avatar
Bossman7121
Well, I did it, and got her stuck in the muck while making a u-turn. I didn't think I was in that bad until I couldn;t rock it even a few inches. Deceided to try 4low and low gear to crawl over some branches, only to finally have 6 guys in an old f150 2wd with bad tires and a hitch pull me out. Problem is, the truck is now stuck in low gear and the low range indicator light is on. Limped home, covered in muck complete with pulled neck. I have a lot of highway driving tomm., and need to at least get it into high. Please HELP! ! ! !
P.S. Also posted in 7.3 forum
Old Jan 18, 2004 | 09:00 PM
99f350sd's Avatar
99f350sd
ESOF???
Old Jan 18, 2004 | 09:22 PM
FortyFords's Avatar
FortyFords
Are we to assume you that you know the procedure to shift it out of 4lo ?
1)trans in neutral
2)completely stopped
3)foot firmly on the brake
4)shift the **** to off
If that doesn't work slowly back up a few feet then try above procedure again.
Still not working chk fuses and relays for the system,all wiring connections to the shift motor.
Rich
Old Jan 19, 2004 | 05:58 PM
Bossman7121
Got it out halfway down the driveway this am. My old scout had to be rolling not stopped so I didn't even think about stopping and in neutral. Anyway, thanks for the info, it worked. Don;t want that to ever happen again, getting stuck and all. Might go for some air lockers soon just in case. I had two opposite wheels spinning away. Thanks again guys.
99f350sd whats ESOF?
Old Jan 19, 2004 | 06:48 PM
99f350sd's Avatar
99f350sd
electric shift on the fly
