Dash brake light
Old Jan 18, 2004 | 03:13 PM
skeneguy's Avatar
skeneguy
Dash brake light
1982 F150 I6
Can anyone tell me the purpose of the brake warning light on the dash?
Old Jan 18, 2004 | 03:28 PM
torquemeister's Avatar
torquemeister
It should be on when your e-brake is on. It also indicates a problem with your brake system (I've seen it stay on when the power booster went bad, and it just always stays on until the problem is fixed).
TM
Old Jan 18, 2004 | 04:55 PM
skeneguy's Avatar
skeneguy
Thanks. Mine doesn't come on with the e-brake, but it started flickering recently. Guess I'm losing pressure somewhere.
Old Jan 18, 2004 | 09:03 PM
bremen242's Avatar
bremen242
It could be that switch on the ebrake is loose and making it flicker. Also, check the fuse. My dash lights where flicking because the fuse blew a enough to crack the filtament and when you hit a bump the lights would go on and off.
Old Jan 18, 2004 | 10:53 PM
locknkey's Avatar
locknkey
Basically its meant to signal that one of the componants in the brake system is faulty, i.e. air in the system, low brake fluid,brake booster leaking pressure.
Old Jan 18, 2004 | 11:22 PM
brown 4x4's Avatar
brown 4x4
Only the later trucks (84-up IIRC) have a switch on the e-brake. Before that, the only way the light can come on is if there's a loss of pressure. Also as a test of the system, when the key is turned to "start".
Old Jan 18, 2004 | 11:48 PM
skeneguy's Avatar
skeneguy
There's not an obvious fluid leak, both reservoirs are full, and the brakes work fine. The light will fade in and fade out, so it definately looks like it's pressure (or lack of) activated.
Old Jan 19, 2004 | 07:53 AM
plowpusher's Avatar
plowpusher
take a zip tie and pull up on your E-brake pedal then tie it to your e brake release 5 will get you 10 the light quits blinking at you
Old Jan 19, 2004 | 12:46 PM
skeneguy's Avatar
skeneguy
I think you're right plowpusher, it came on, I kicked the e-brake and it went off. I'm not using the e-brake these days as I'm not always guaranteed a complete release at the drums - Spring time job.
Old Jul 27, 2004 | 03:03 PM
hermangarza's Avatar
hermangarza
my 81 has the light but when i press the e-brake the light does not come up.
thanks
Old Jul 27, 2004 | 06:32 PM
skeneguy's Avatar
skeneguy
Mine doesn't come on with the e-brake either. Actually the problem went away when I got the rear cylinders replaced.
Old Jul 27, 2004 | 10:03 PM
bremen242's Avatar
bremen242
The brake light works with the e-brake after 83 I think.. If the light is on otherwise, that means that the proportion valve piston isn't centered.. ie your brakes have air in the lines or they are leaking..
Old Jul 27, 2004 | 10:09 PM
bigbrown84truck's Avatar
bigbrown84truck
while we are talking about the dash lights, what is up with the shift light. when is this supposed to work?
Old Jul 27, 2004 | 10:26 PM
bremen242's Avatar
bremen242
dunno, mine never worked.. On '85+ it is a light that flashes 'emissions'
Old Jul 27, 2004 | 11:17 PM
locknkey's Avatar
locknkey
Its supposed to work when your engine has past the 60,000 mile service mark and flashed so you can be a good Ford person and take your auto to the nearest FORD Dealership to have them charge you lots of your money to turn it off, by the way, its resettable under the dash with a small screwdriver with the key in the on position (oops, sorry about that slipup) There is the correct way of resetting it if it comes on, do a search for it here....some people have already discovered how to do it and explains it better than I just did...
