427 block/428 crank
Old Jan 18, 2004 | 01:30 PM
scroob's Avatar
scroob
427 block/428 crank
I know that 427 blocks just aren't falling off of trees these days, but how common is this combination?
Math says you'd have a 448 cu. in. engine with tons of stroke.
Would there be issues with deck height? Pistons?
Old Jan 18, 2004 | 01:42 PM
Scouder's Avatar
Scouder
It is a very common combination among those lucky enough to own a 427 block. The 428 crank uses the standard 427 rods and most piston manufacturers have a piston on the shelf with the correct compression height. If there is a downside it is that you may not want to run it to 7500rpm anymore, though some do.
-Scouder
Old Jan 18, 2004 | 05:23 PM
gtex's Avatar
gtex
Isn't this the combination that at .030 over gives you a 454?.....the Cheby guys love that :-)
Old Jan 18, 2004 | 05:30 PM
fordman428's Avatar
fordman428
yep thats the combination for the 454, 454.7 to be exact
Old Jan 18, 2004 | 09:25 PM
baddad457's Avatar
baddad457
I did this with my 427 way back in the 80's. TRW had the pistons then for the crank swap. And , yes it drove the Chevy guys nuts when you said it was a 454, but had the wrong valve covers.
