Cold starts, help needed
Old Jan 24, 2004 | 08:45 PM
Putt's Avatar
Putt
I believe what Scouder was referring to was that if the carb is set at the right fuel mix to run when warm, it will be too lean to run well when the engine is cold. I have had good luck running the choke plate slightly modified. I cut off the lower corners at an angle to allow more air in, it allows the high idle to work without flooding the engine from the blocked airflow. If the engine is running lean enough for max power it should be difficult to keep running when cold without the assistance of the choke and high idle cam. IMHO
Putt
Old Jan 24, 2004 | 08:51 PM
Ratsmoker's Avatar
Ratsmoker
That is a good point Putt. That may explain my carb issues. I have the choke set as lean as possible and it still floods. Maybe I can lower my high idle a bit. It will idle at about 3,000rpm when warm and the high idle is on.
Old Jan 24, 2004 | 11:41 PM
Putt's Avatar
Putt
It works really well because it allows you to pull the choke all the way on to "set" the fast idle, but it prevents excess fuel from flowing. Holley's don't need much extra fuel when starting! My truck starts right up no matter how cold it gets- like -22*! BRRRR!
Putt
Old Jan 25, 2004 | 12:27 PM
76supercab2's Avatar
76supercab2
I think that if you want to have a high idle with no choke then leave the choke plate off and adjust the high idle screw for 2000 rpm when engaged.
I still think you should put the choke plate back on though.
dcombs
1966 - 1977 Early Broncos
Feb 19, 2015 05:27 PM
Rusty_S
13
May 20, 2014 11:00 AM
Johnnypowerstroke
Sep 10, 2012 07:07 AM
benwantland
Nov 5, 2009 06:07 AM
ndx
Mar 3, 2005 07:55 AM
