EGR problem please help
Old Jan 19, 2004 | 04:42 PM
brown 4x4's Avatar
brown 4x4
Very interesing topic guys. Let me add this. What about the EVP sensor? Even if the computer had no other way of knowing the EGR wasn't operating, this sensor gives it away. The computer tells the EGR to open, expecting this sensor to tell it that it opened. If the sensor is saying nothing's happening, you'll throw a code. I'm guessing it would be "insufficient flow".
Old Jan 19, 2004 | 04:48 PM
quaddriver's Avatar
quaddriver
again without my book nearby to help my fuzzy memory (hey I just lost the throttle valve in my chevy tranny today so Im preoccupied)
if the EVP does not indicate the EGR has moved then there are a couple codes it can select....the insufficient flow has at least 2 causes in the step guide....one of the more sublte one being an unexpected O2S and MAP reading - and if Im not mistaken, the ECM (in at least OBD2) will choggle the EGR a little to look for a change before it gripes - I am not sure if EECIV does the same
Old Jan 19, 2004 | 08:04 PM
BigRedBronc's Avatar
BigRedBronc
OK, this topic has gotten really old.
If you want to remove your EGR, have a ball.
You are absolutely right...
and 2000 automotive design engineers are wrong...
My humblest apologies.
There, now shall we find something else to talk about.
Thanks.
(P.S. spellcheck is a wonderful tool, try it, you'll like it)
Have a nice day.
Old Jan 19, 2004 | 10:19 PM
yellowjeep76's Avatar
yellowjeep76
the evp gives codes regarding incorrect voltages, egr not opening, and circuit failure when the egr valve does not operate or the evp is screwed up. the evp only gives information on the exhaust valve positon, which is the egr. I beleive that on trucks from 87-91 there is only the evp and no flow sensor. On trucks 92 and later, i believe that they include a flow sensor.
Thorntontribe
Nov 23, 2014 03:30 AM
luketrot
Sep 18, 2010 05:47 PM
duallygirl
Jul 29, 2006 11:05 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Aug 7, 2003 09:06 AM
