fuel pump 94 explorer
Old Jan 18, 2004 | 12:54 AM
steve88's Avatar
steve88
I'm having to install my 3rd fuel pump in 3 years on my 94 explorer - I'm wondering if there is something causing my pumps to burn out early.
Is the voltage to the fuel pump supposed to be the same as the battery voltage? Is this pretty much standard on all vehicles - for example is the voltage on the fuel pumps of my 88 F150 also 12 v?
Any thoughts would be welcome - I'm at the point where i'm thinking of drilling a hole in the bottom of the vehicle so i don't have to wrestle with the fuel tank.
Thanks.
Old Jan 18, 2004 | 05:54 AM
Opera House Works's Avatar
Opera House Works
Fuel pressure is controled by shunting fuel back to the tank. Approximately 80% of the fuel pumped is returned back to the tank. This extra fuel flow is used to cool the pump. You have not mentioned if you have ever measured fuel pressure. If there was a restriction in the line to the regulator, the fuel rail pressures would be normal but the flow woulf be reduced. This would put extra strain on the motor. The fuel pump fuse can be removed and pump current measured at the socket. It should be about 5A. If anything is abnormal, it would show up in the motor current.
Dutter 2
Jan 2, 2017 12:02 PM
TN_Explorer
Aug 20, 2016 07:45 PM
Gun-Driver
Feb 16, 2016 01:25 PM
efiles123
Dec 13, 2015 11:59 AM
jamgood96
1983 - 2012 Ranger & B-Series
Apr 13, 2014 03:35 PM
