Bronco II Ford Bronco II
slave cylinder help
Old Jan 17, 2004 | 08:43 PM
CrazyFazy's Avatar
CrazyFazy
slave cylinder help
I have to add fluid everday to my reservoir so I guess my slave cylinder is shot. Is their any way possible to change this without pulling tranny?
Old Jan 17, 2004 | 11:39 PM
Mr Mopar's Avatar
Mr Mopar
If the slave cylinder is inside the bellhousing (it probably is) the simple answer is No, but before you condemn the slave cylinder, be sure the line to it isn't the culprit
Old Jan 18, 2004 | 09:23 PM
mrshorty's Avatar
mrshorty
Whether you have to pull the tranny depends on which transmission you have. I have an '87 FM146, and the slave cylinder is inside the bellhousing. Some earlier transmissions have an external slave cylinder. Of course, as noted, make sure the fault doesn't lie in something external to the bellhousing before going to the trouble of pulling it.
farmer07
Dec 28, 2009 06:54 PM
bugracer64
May 24, 2009 11:03 AM
bigtread
May 20, 2007 06:47 PM
rbloodhound
May 13, 2007 05:57 PM
brosko80
Mar 9, 2006 03:58 PM
