95 Ranger EEC Test Connector
Old Jan 17, 2004 | 04:11 PM
foxx's Avatar
foxx
I borrowed a Autoxray EZ-READ 2000 Scanner from a friend. And having trouble finding the EEC Test Connector on my 1995 Ranger. 2.3L, Manual Trans, Ext. Cab. I was hoping someone could point the way. Thanks!!
Old Jan 17, 2004 | 04:17 PM
luckild's Avatar
luckild
Welcome to FTE. Look on the left inner fender, usually in a plastic housing marked EEC connecter, CLOSE TO THE BRAKE MASTER CYLINDER. Good luck.
Old Jan 17, 2004 | 06:52 PM
hreed's Avatar
hreed
The 95 port for the scanner us under the steering wheel behind a small removable plastic cover. It should be an obd II plug, however depending on the month your truck was made, the standard obd II may not work. Not sure the exact month, but I think anything built after July 95 is standard obd II. Anything before that is a "modified" (best word I can think of to describe it) system. My 95 Ranger is obd II, however, it was built in March, and most scanners will not read the codes. I finally found the Auto Xray 2000 will read the codes, but only in the "generic" mode. Let me know how it goes. It should work. If your truck is later than July, you will need to get the vin code (8th digit). It should be on the driver's door.
hofdaddy
Jul 28, 2007 08:17 PM
xamack24
May 5, 2004 12:23 PM
storminator
Jan 30, 2004 08:27 PM
jmcdaniel99
Bronco II
Sep 16, 2003 08:46 AM
