1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
4R100 or 4R70W How to tell which one?
Old 01-16-2004, 07:04 PM
njxlt's Avatar
njxlt
njxlt is offline
How can I tell what tranny I have in my 1998 XLT 5.4 Expedition? Is one common with the 4.6 and another with the 5.4? Do I use my VIN # on a chart? Anyone know how to tell this info out?
Old 01-16-2004, 10:53 PM
PaulC's Avatar
PaulC
PaulC is offline
Go to the Vehicle Certification Label located on the driver's door. Under the barcode, look for "TR". Below "TR" will be the code for the transmission type. "E" = E40D (pre 4R100), "U" = 4R70W.
Old 01-17-2004, 11:48 AM
buzzard's Avatar
buzzard
buzzard is offline
One can visually tell the difference fairly easily. The 4R100 is a big boxy case with a grid pattern on it while the 4R70W is a more rounded (traditional bell housing) type tranny.
Old 01-17-2004, 12:18 PM
bobcf's Avatar
bobcf
bobcf is offline
4r100 has 20 bolts around the big drain pain,4r70 has less around a smaller pan
Old 01-19-2004, 11:55 AM
my98expy's Avatar
my98expy
my98expy is offline
just piggy backing on your question. Which tranny is better?
Old 01-19-2004, 12:14 PM
PaulC's Avatar
PaulC
PaulC is offline
The 4R70W is also found in grandmother's Ford Crown Victoria. The 4R100 is also found in V8 Ford F-250's.
Old 01-19-2004, 12:36 PM
buzzard's Avatar
buzzard
buzzard is offline
The 4R100 is supposedly a heavier duty tranny behind the larger engines, but I read the new Expy specs and it says the 4R70W is rated for 500+ ft.lbs. of torque which ain't too shabby.
Unless one is extremely demanding on a vehcile, either tranny should perform equally well.
Old 12-04-2023, 09:40 AM
TPozos's Avatar
TPozos
TPozos is offline
1st Gear
I'm lost
I see nothing that says a 4R100 nor 4R70W. I need the specs for a transmission cooler. But don't understand how to get the transmission type out of these numbers on my 2001 expedition 5.4 v 8
Old 12-04-2023, 11:08 AM
alloro's Avatar
alloro
alloro is offline
Received 4,254 Likes on 2,480 Posts
Like PaulC said, "Below "TR" will be the code for the transmission type. "E" = E40D (pre 4R100), "U" = 4R70W."
So you have an E40D (4R100) transmission.
Old 12-04-2023, 02:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,643 Likes on 1,102 Posts
The 4R70W is rated for 700 lb-ft of torque at the input shaft. This is after the torque converter multiplies the torque. Since the converter approximately has a 2:1 torque multiplication, that equates to about 350 lb-ft at the crankshaft.
The 4R100 is rated for 1000 lb-ft at the input shaft, or about 500 lb-ft at the crankshaft.
The following users liked this post:
smife
01-07-2013 10:21 AM
93 mix 'n match
1997 - 2003 F150
13
04-09-2010 10:40 AM
pos2nat
08-09-2005 11:50 PM
Paul Tocko
1997 - 2003 F150
04-11-2004 01:12 PM
njxlt
13
08-02-2003 12:34 AM
Quick Reply: 4R100 or 4R70W How to tell which one?
